Mopar conversion #2723457
12/12/19 12:48 PM
12/12/19 12:48 PM
Lebanon ,PA in the Susquehanna...
70Challengerse Offline OP
Anyone know where I can find the bell housing for a 440 to bolt on 4l65e chevrolet trans, didn't know if anyone sells it separate , dont want to buy a whole kit, also need the flywheel/ flex plate... I have everything else, just cant find these .. thanks
Re: Mopar conversion [Re: 70Challengerse] #2723462
12/12/19 01:19 PM
12/12/19 01:19 PM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
I believe on this bellhousing you must use the LS style 4l60e/4l65e based transmission which uses a larger torque convertor and longer input shaft than the 97-2002 Vortec based 4l60e type transmission, it will save you some headaches if you end up with the wrong transmission.
http://www.moderndriveline.com/shop...uicktime-mopar-383-400-426-440-to-4l60e/
Re: Mopar conversion [Re: chargerbr549] #2723482
12/12/19 02:41 PM
12/12/19 02:41 PM
I saw that one before, but isn't there a gm bell housing with a flywheel conversion.. Trans isn't a problem, have tons of them.
Re: Mopar conversion [Re: 70Challengerse] #2723499
12/12/19 03:42 PM
12/12/19 03:42 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Haven't checked every item available but could be there ariound here maybe ?
https://www.holley.com/products/drivetrain/bellhousings/mopar/
EDITING, nevermind, not 4L65E on the list
Re: Mopar conversion [Re: NachoRT74] #2723505
12/12/19 04:08 PM
12/12/19 04:08 PM
Silver sport has one, but won't sell it,don't want to break up a kit, what ever... JW Performance is putting together a kit for me , where you use a newer mopar starter.. with one of their ultra bells, direct bolt it...so far they are the only ones helping... up I can't see spending 4-5 grand when I can do everything else.. cross member, driveshaft, trans, etc...
Re: Mopar conversion [Re: 70Challengerse] #2723510
12/12/19 04:25 PM
12/12/19 04:25 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Just a question. Why are you going to that swap?
Re: Mopar conversion [Re: stumpy] #2723521
12/12/19 04:55 PM
12/12/19 04:55 PM
You cant beat the quality of shift you get with a 4l65, no cutting like the 518,I do drive trains and transmission for a living,I wanted to do this earlier ,but Silver Sport Trans is the only game in town and they wont sell me parts, just a complete kit, thats fine that their business, I understand.. but I'm not gonna spend thousands.. this is actually a simple swap, Waited for someone else to make a bell...I talked to Stu before his passing, for alittle insight, to see if was pleased, he was more than happy, I have a gear vender in now, it works well, but clunky as heck.. This will be user friendly and a bolt in.... up
Re: Mopar conversion [Re: 70Challengerse] #2723526
12/12/19 05:39 PM
12/12/19 05:39 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Ok, thanks.
Re: Mopar conversion [Re: 70Challengerse] #2723588
12/12/19 09:02 PM
12/12/19 09:02 PM
Las Vegas, NV
Las Vegas, NV
So they are making an Ultrabell bellhousing that will bolt a big block mopar directly to a Vortec based 4l60e? If so thats very interesting since it looks like using the quicktime bellhousing with the LS based 4l60e is tends to move the trans to far into the tunnel on the 70 and older B Bodies and you have to start doing tunnel modifications to make it fit.
Re: Mopar conversion [Re: chargerbr549] #2723594
12/12/19 09:48 PM
12/12/19 09:48 PM
no. just the trans with bell attached, has to be removed ,just like the bell on a 518, witch I have no problem with, pretty much 93-2002 ? not the bolt ons...Not the 300 mm shafts
Re: Mopar conversion [Re: 70Challengerse] #2723597
12/12/19 10:12 PM
12/12/19 10:12 PM
Las Vegas, NV
Las Vegas, NV
So just to clarify they are making the Ultra bell bellhousing fit the the 4l60e transmission with the non-removable bellhousings and obviously cut the bell housing off like the 518 transmission? My assumption is this might work for the 700r4 transmission as well? Do you have a part# and cost?
Re: Mopar conversion [Re: chargerbr549] #2723606
12/12/19 11:05 PM
12/12/19 11:05 PM
Yes.... I'll have it next week, hoping this is what I need, I'll get you the part #
Re: Mopar conversion [Re: 70Challengerse] #2723625
12/13/19 12:26 AM
12/13/19 12:26 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
let us know how it works out.
The TCI 6x (4l80?) trans kit for Mopar Big block that Mike is using in his '69 Coronet moves the trans closer to the back of the engine and there is a spacer that moves the starter away from the bell housing. This created problems with the header tube, that needed to be cut out and a new one installed to clear the re-located starter.
Re: Mopar conversion [Re: 451Mopar] #2728610
12/31/19 03:49 PM
12/31/19 03:49 PM
Las Vegas, NV
Las Vegas, NV
Any updates on the bellhousing?
Re: Mopar conversion [Re: chargerbr549] #2733187
01/14/20 11:06 PM
01/14/20 11:06 PM
Got it , its on and in the Challenger, plenty of room,ordered the wrong flywheel, my fault,be here in acouple days, ordered a 6 bolt , I have a 8 bolt crank.... driveshaft is ordered cross member is fabbed up,alittle work other than that , no issues....will keep you in the loop
Re: Mopar conversion [Re: 70Challengerse] #2734346
01/18/20 10:54 PM
01/18/20 10:54 PM
soon there.
Re: Mopar conversion [Re: 70Challengerse] #2737017
01/27/20 10:07 AM
01/27/20 10:07 AM
part # for the bellhousing is 92456-700
part # for the flywheel 6 bolt 93009-c flywheel adapter 80012
part # for the flywheel 8 bolt 93010-c flywheel adapter 80013
this was alot easier than I thought, you can use your factory starter, but they prefer the later , smaller one, I'm running a 89 dodge truck starter for years now...
JW Performance 321-632--6205
Re: Mopar conversion [Re: 70Challengerse] #2737378
01/28/20 10:13 AM
01/28/20 10:13 AM
Las Vegas, NV
Las Vegas, NV
Do you have any pics on the with the bellhousing and transmission mocked-up before it was installed? What was the cost of the bellhousing?
