383 oil pump ? #2723128
12/10/19 11:34 PM
12/10/19 11:34 PM
Canada
roy282 Offline OP
roy282  Offline OP
Canada
Hello again,
was hoping someone would know what oil pump this is tried looking up the # but came up with nothing so I'm asking here.
Rob
Re: 383 oil pump ? [Re: roy282] #2723136
12/11/19 12:14 AM
12/11/19 12:14 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Standard big block oil pump. Looks like a sealed power number maybe.
Re: 383 oil pump ? [Re: stumpy] #2723138
12/11/19 12:29 AM
12/11/19 12:29 AM
Canada
roy282 Offline OP
roy282  Offline OP
Canada
Thanks for reply, but not what I was hoping to hear, thought maybe it was a high volume aftermarket oil pump
Thanks,
Rob
Re: 383 oil pump ? [Re: roy282] #2723141
12/11/19 12:36 AM
12/11/19 12:36 AM
Grand Prairie,Texas
Grand Prairie,Texas
How thick is the body of the pump between the engine and the outer piece? High volume pumps are noticeably thicker then stock. Your picture doesn't show that part, In most cases a high volume pump isn't necessary. Why do you think you need it?
Re: 383 oil pump ? [Re: stumpy] #2723143
12/11/19 12:46 AM
12/11/19 12:46 AM
Canada
roy282 Offline OP
roy282  Offline OP
Canada
What do you think now? Stock EH!
Rob
Re: 383 oil pump ? [Re: roy282] #2723144
12/11/19 12:48 AM
12/11/19 12:48 AM
Grand Prairie,Texas
Grand Prairie,Texas
It looks thicker than stock but I'm not certain. You might want to post this in the race section. Those guys are really good at this.
Re: 383 oil pump ? [Re: stumpy] #2723148
12/11/19 01:28 AM
12/11/19 01:28 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
HV pump, the newer HV pumps come with a high pressure spring, you have a stock type pump.
Re: 383 oil pump ? [Re: roy282] #2723180
12/11/19 09:21 AM
12/11/19 09:21 AM
an8sec70cuda Offline
Thanks,
Rob
If you're running a stock oil pan and your oil clearances aren't on the loose side, then a stock type pump is what you want.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 383 oil pump ? [Re: an8sec70cuda] #2723287
12/11/19 05:17 PM
12/11/19 05:17 PM
Canada
roy282 Offline OP
roy282  Offline OP
Canada
Thanks for your reply's
the 383 hp motor I picked up came with this oil pan and windage tray plus the aftermarket carter performance fuel pump so I thought maybe the oil pump was hv?Is there a way to tell by taking it off?
Mancini Racing B/RB 5 Qt Oil Pan
Fits: Big Block, B/RB
5 quart oil pan is based off Chrysler "971" Stamping. fits
Rear Main Seal Style: 2-piece
Sump Location: Center
Stroker Clearanced: No
Maximum Stroke with OE Rod: 3.750 in.
Sump Style: Wet
Oil Pan Capacity: 5.00 quarts
Oil Pan Depth (in): 5.250 in.
Oil Pan Material: Steel
Oil Pan Finish: Natural
Baffled: Yes
Kicked Out: No
Dipstick Provision: Yes
Windage Tray Included: No
Pickup Included: No
Crank Scraper Included: No
Drain Plug Thread Size: 1/2-20 in.
Gaskets Included: No
Hardware Included: No
Rob
Re: 383 oil pump ? [Re: roy282] #2723289
12/11/19 05:24 PM
12/11/19 05:24 PM
Grand Prairie,Texas
Grand Prairie,Texas
Standard pump would be fine for that set up. No need to take it off. You can tell by the difference in measurements that you have a standard pump.
Re: 383 oil pump ? [Re: roy282] #2723291
12/11/19 05:27 PM
12/11/19 05:27 PM
The thickness of the pump body is how you tell if it's a high volume pump or not. Your pump appears to be about 1/4" shorter than the HV pump pictured above, so yours would be a standard volume pump.
Like I said, not a bad thing and it's likely all it needs.
CHIP
Re: 383 oil pump ? [Re: an8sec70cuda] #2723306
12/11/19 06:03 PM
12/11/19 06:03 PM
Canada
roy282 Offline OP
roy282  Offline OP
Canada
Awesome thanks for your reply's!! always learning!!!
Re: 383 oil pump ? [Re: roy282] #2723307
12/11/19 06:09 PM
12/11/19 06:09 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
also the picture of that engine, there is not a windage tray installed
Re: 383 oil pump ? [Re: CSK] #2723318
12/11/19 06:28 PM
12/11/19 06:28 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
And it does not look like a new pan.
Re: 383 oil pump ? [Re: BSB67] #2723342
12/11/19 08:24 PM
12/11/19 08:24 PM
Canada
roy282 Offline OP
roy282  Offline OP
Canada
Good eye! yes I know because I removed the oil pan to restore it check it out!
Re: 383 oil pump ? [Re: roy282] #2723359
12/11/19 09:26 PM
12/11/19 09:26 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Stock "nothin' fancy" replacement pan - not even a larger capacity "hemi" pan. The last guy just cheaped out, don't expect to find any bonuses in this motor.
Re: 383 oil pump ? [Re: Stanton] #2723436
12/12/19 12:21 PM
12/12/19 12:21 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
971 came with baffles front and rear, 5 quarts plus filter nominal fill, to my way of thinking that's actually not a
horribly bad street performance kind of a piece.
The pump just looks like a stock piece but that's okay, if this is a stock-ish kind of a build I'd add a windage tray
and that's about it,
Rich H.
Esse Quam Videri
Re: 383 oil pump ? [Re: ZIPPY] #2723591
12/12/19 10:36 PM
12/12/19 10:36 PM
Canada
roy282 Offline OP
roy282  Offline OP
Canada
Thanks ZIPPY That's what I thought about the pan a little better then stock so I restored it.Not building a race car just a nice cruiser...
cheers
Rob
Re: 383 oil pump ? [Re: stumpy] #2723607
12/13/19 12:07 AM
12/13/19 12:07 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
As far as oil pumps,I've had this one a "long" time,ask before and never got a legitimate an answer.New in Chrysler box,I'd have to look but if I remember correctly,part number starts at 25 something,never could find any reference to the number. The M63 on the pump is also on the box shruggy
Re: 383 oil pump ? [Re: 62maxwgn] #2723628
12/13/19 01:56 AM
12/13/19 01:56 AM
Grand Prairie,Texas
Grand Prairie,Texas
