Re: Spark Plug reccomendation's 440
[Re: 1974 474 Duster]
#2722923
12/10/19 12:03 PM
12/10/19 12:03 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
#2722975
12/10/19 02:18 PM
12/10/19 02:18 PM
Posts: 43,180 Bend,OR USA
Cab_Burge
Autolite #75,74 or # 85,84. Champion RJ10YC, RJ12YC or R12Y or R10Y if you can find those last two part numbers still Not sure on the current NJK part #s 10.5 to 1 compression ratio with iron heads is a gamble on detonation with todays pump fuel, be careful on the tuning Colder plugs are usually needed also, like Autolite #73 or #83, Champion RJ6 or colder also
[Re: Lee446]
#2723557
12/12/19 08:13 PM
12/12/19 08:13 PM
Posts: 4,720 Moved to N.E. Tennessee
GomangoCuda
Not to hijack, but in this application are there any equivalents that use a 5/8" hex plug for header flange clearance? Not that I am aware of. 1974 474 Duster - in a similar engine I use NGK 3332. Also known as XR5. I have never fouled a plug. I think it would idle until it ran out of gas. Lol. Of coarse Your results may vary depending on state of tune. Hint - with that cam it will like 18-20 deg advance at idle.
