Spark Plug reccomendation's 440 #2722918
12/10/19 11:40 AM
12/10/19 11:40 AM
Rochester, PA (near Pittsburgh...
1974 474 Duster Offline OP
Hey just looking for recommendation's here on my Road Runner. 440 about 10 1/2 comp .525 hydraulic Comp cam. Iron 452 ported heads 750dp MSD, headers
Haven't un iron heads in years, just looking to see what direction I should go please.
Thanks, Ken
Re: Spark Plug reccomendation's 440 [Re: 1974 474 Duster] #2722919
12/10/19 11:43 AM
12/10/19 11:43 AM
Kirkland, Washington
Pacnorthcuda Offline
Autolite AP85.
Re: Spark Plug reccomendation's 440 [Re: 1974 474 Duster] #2722923
12/10/19 12:03 PM
12/10/19 12:03 PM
an8sec70cuda Offline
NGK 2891 (R5670-7)
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Spark Plug reccomendation's 440 [Re: 1974 474 Duster] #2722975
12/10/19 02:18 PM
12/10/19 02:18 PM
Autolite #75,74 or # 85,84. Champion RJ10YC, RJ12YC or R12Y or R10Y if you can find those last two part numbers still luck
Not sure on the current NJK part #s confused
10.5 to 1 compression ratio with iron heads is a gamble on detonation with todays pump fuel, be careful on the tuning twocents
Colder plugs are usually needed also, like Autolite #73 or #83, Champion RJ6 or colder also scope
Re: Spark Plug reccomendation's 440 [Re: an8sec70cuda] #2723129
12/10/19 11:34 PM
12/10/19 11:34 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Originally Posted by an8sec70cuda
NGK 2891 (R5670-7)
Ken if I can remember I can bring you a set tomorrow! Free of course. Remind me if you can.
Re: Spark Plug reccomendation's 440 [Re: max_maniac] #2723372
12/11/19 11:08 PM
12/11/19 11:08 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Not to hijack, but in this application are there any equivalents that use a 5/8" hex plug for header flange clearance?
Re: Spark Plug reccomendation's 440 [Re: Lee446] #2723557
12/12/19 08:13 PM
12/12/19 08:13 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Not that I am aware of.
1974 474 Duster - in a similar engine I use NGK 3332. Also known as XR5.
I have never fouled a plug. I think it would idle until it ran out of gas. Lol.
Of coarse Your results may vary depending on state of tune.
Hint - with that cam it will like 18-20 deg advance at idle.
