damper thoughts running a gear drive #2722973
12/10/19 02:16 PM
12/10/19 02:16 PM
moparx Online content OP
moparx  Online Content OP
what are your thoughts on choosing a damper when running a gear drive ?
any good damper ? fluid damper ? doesn't make any difference ? why ? street, street strip, or race mean anything ?
TIA as always ! bow
beer
Re: damper thoughts running a gear drive [Re: moparx] #2722978
12/10/19 02:21 PM
12/10/19 02:21 PM
ATI 3 ring dampeners regardless up scope:twocents
My current SP E85 motor has a ATI 3 ring on it, just like all the rest of the motors I've built in the last 5+ years, they work very well up
Re: damper thoughts running a gear drive [Re: Cab_Burge] #2722991
12/10/19 02:57 PM
12/10/19 02:57 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Everybody's preference is the ATI but the Fluidamper looks more stock on a Street Hemi it that matters to you.
2011 Drag Pak Challenger
Re: damper thoughts running a gear drive [Re: rickseeman] #2722995
12/10/19 03:09 PM
12/10/19 03:09 PM
an8sec70cuda Offline
I have an ATI on my hemi and a Fluidamper on the 440. Both seem to work fine.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: damper thoughts running a gear drive [Re: moparx] #2723001
12/10/19 03:29 PM
12/10/19 03:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I run fliuldamper on my 416ci with a gear drive.. have been for years now
wave
Re: damper thoughts running a gear drive [Re: MR_P_BODY] #2723012
12/10/19 04:01 PM
12/10/19 04:01 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Ati. Fluidampers are HEAVY!
Re: damper thoughts running a gear drive [Re: fbs63] #2723015
12/10/19 04:08 PM
12/10/19 04:08 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Part of how they work.
Boffin Emeritus
Re: damper thoughts running a gear drive [Re: polyspheric] #2723020
12/10/19 04:23 PM
12/10/19 04:23 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
ATI here also with gear drive, several motors.
Re: damper thoughts running a gear drive [Re: old_racer] #2723043
12/10/19 06:00 PM
12/10/19 06:00 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
I have a TCI Rattler with a gear drive on a small block.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: damper thoughts running a gear drive [Re: moparx] #2723064
12/10/19 07:23 PM
12/10/19 07:23 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I like a fluid damper for my race engines. On a street engine, I have been told that if you run a fluid damper in cold weather the silicone fluid gets thick and may cause issues. So I just run a stock elastomer type balancer that is sfI approved on street engines.
Re: damper thoughts running a gear drive [Re: jwb123] #2723108
12/10/19 10:42 PM
12/10/19 10:42 PM
Washington
madscientist Offline
Washington
I drive my car at well below freezing and my FD has never had an issue.
Re: damper thoughts running a gear drive [Re: madscientist] #2723121
12/10/19 11:23 PM
12/10/19 11:23 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
A picture tells the story!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: damper thoughts running a gear drive [Re: hemi-itis] #2723124
12/10/19 11:27 PM
12/10/19 11:27 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
ATI 917127E fits both Jesel belt drives and gear drives. @AndyF
Andy is a good resource for this kind of info too.
Re: damper thoughts running a gear drive [Re: Jeremiah] #2723154
12/11/19 06:20 AM
12/11/19 06:20 AM
gregsdart Offline
gregsdart  Offline
For a Milodon geardrive/super damper combo a special damper hub is requiered. $119! And don't under any circumstances buy a used damper. The ATIs may have to have all the bolt heads drilled out/off to disassemble. It might be worth asking if anti sieze can be put on the shoulders of the bolt heads before installation. I had to drill mine to dissassemble for rebuilding. I tried soaking them in wd40, penetrating oil, still broke multiple allen sockets.
Re: damper thoughts running a gear drive [Re: gregsdart] #2723209
12/11/19 11:17 AM
12/11/19 11:17 AM
interesting replies fellows. thank you !
any others ?
beer
Re: damper thoughts running a gear drive [Re: moparx] #2723229
12/11/19 01:17 PM
12/11/19 01:17 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Every chart I have seen, even those published by ATI, shows the FD more effective for its intended design below 6500? rpm, seems like the expected use would be a factor in deciding.
That being said, I have both. biggrin
Re: damper thoughts running a gear drive [Re: jcc] #2723273
12/11/19 04:30 PM
12/11/19 04:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I ran my FD to 8200 on every pass with zero issues and now on my 418
wave
Re: damper thoughts running a gear drive [Re: MR_P_BODY] #2723282
12/11/19 05:01 PM
12/11/19 05:01 PM
AndyF Offline
AndyF  Offline
The differences in dampening between an ATI and a Fluid damper are pretty small. Bracket racers would never notice the difference. NASCAR engine builders need to pay attention to this stuff though. I'm pretty sure all NASCAR engines get tuned ATI dampers these days.
For bracket racing or street duty just use whatever fits. For serious drag racing I'd probably use an ATI unit.
Finding something that fits is the important thing. ATI makes a version with a longer hub that fits belt drives and gear drives so that is one option I'd look at.
Re: damper thoughts running a gear drive [Re: AndyF] #2723336
12/11/19 07:37 PM
12/11/19 07:37 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
"Stop the presses panic
So I went online to locate the ATI graph/chart that I thought I just recently viewed in the newest ATI product catalog I got in the mail. The online graph does not jive with what I shared here regrading the comparison of ATI vs FD in rpms.
I will get a copy of ATI's catalog at PRI Thursday and I might have to retract my incorrect comment. Sorry"
So the attached pic is from the latest "ATI 2020 Winter catalog".
As AndyF has already noted there are many variables in tuning a damper. I suspect there are at least 12? known elected variables that they account for in the final design. I'd bet there are another dozen variables felt too difficult to measure or insignificant enough to design in, and I also suspect there is an infinite of unknown undiscovered other variables also at play. All to mean, pic your poison.
So I also suspect ATI being a for profit corporation, picked a specific ATI damper to best promote their marketing strategy. I'd give them the benefit of doubt and believe they did not pick competitor test example s that would test poorly.
That being said, all three dampers in the graph appear to test the same up to approx 5800 rpms, at the point their effectiveness separate, then the FD tests best, until approx 6900 rpm where its non effectiveness quickly climbs, and the ATI becomes more effective as the rpms climb. I would not draw a solid conclusion from this, but I believe its indicative in general as to the best rpms effective range a user could be guided by. Such as if you never seldom operate your engine above say 7000 rpm, the choice is rather clear. None of the above numbers are etched in stone, especially if one refers back to my opening comment on variables and tuning dampers.
Re: damper thoughts running a gear drive [Re: jcc] #2723427
12/12/19 11:31 AM
12/12/19 11:31 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Of the 3-4 balancer companies out there, their products/theory work at different harmonic levels. Some do a general dampening through the rpm range and others are more specific. I've found that harmonics, whether engine, driveshaft, etc, can be many hidden issues that surface and reveal themselves in unexpected ways. There was a chart several years ago that posted the rpm/dampening effects for balancers. Then of course is the whole 1960's-70's Chrysler/Nascar balancer theory that lets balancer weight solve all issues.
