Re: Budget 5.7 Eagle build [Re: HotRodDave] #2709605
10/23/19 06:29 PM
10/23/19 06:29 PM
Australia
L4staero Offline OP
L4staero  Offline OP
Australia
Originally Posted by HotRodDave
Update on the cheap cams, apparently chrysler decided we should not get a good deal on cams anymore, I just called and all the part numbers he looked up for 6.4 cams are $300 including the numbers I put up.
Wow i just checked and even the 419AB mds cam is $195 at Eastcoast.
Lets hope its just a supply restriction that forced the price increase. When the HC blocks were on backorder they doubled the price. When they came off back order the price halved again
Re: Budget 5.7 Eagle build [Re: HotRodDave] #2722874
12/10/19 06:32 AM
12/10/19 06:32 AM
Australia
L4staero Offline OP
L4staero  Offline OP
Australia
I finally got the car running and to the track.
Crudely set AFR to 12.0 in the tune and with competely stock car spark tables it went 12.05@111 at 3525lbs with 1.68 60 ft with a 2200ft DA 1st run and did the 3hr round trip to the track and home again
Still have alot of tuning left to do hope to find another 20-30 hp once tuned properly
Peak power is currently around 6600 rpm and has a super flat power curve with it only dropping off noticable after 7k. The low end torque from the VVT and dual runner intake is incredible far better than anything ive driven of similar cubes in the LA platform and the previous converter is flashing quite a bit higher than it did previously
Ill keep it updated as I progress in the new year
Re: Budget 5.7 Eagle build [Re: L4staero] #2722886
12/10/19 08:56 AM
12/10/19 08:56 AM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
That is pretty good, 12.0 is rich rich, try 12.5-13.0 and I am sure it will pick up a tenth or two. Not bad for a first trip!
68 Barracuda Formula S 340
Re: Budget 5.7 Eagle build [Re: L4staero] #2722961
12/10/19 01:55 PM
12/10/19 01:55 PM
New Braunfels, TX
416challenger Offline
New Braunfels, TX
Not bad for a first outing. I would think it would pick up quite a bit with tuning. You should be able to improve that 60' time a bunch with the gearing and converter that is in there.
Re: Budget 5.7 Eagle build [Re: L4staero] #2723088
12/10/19 09:22 PM
12/10/19 09:22 PM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
Looking forward to seeing what you can get out of this combo, that 6.4 intake great up to 7k , then it hits a brick ,
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: Budget 5.7 Eagle build [Re: Ray408G3Hemi] #2723268
12/11/19 04:08 PM
12/11/19 04:08 PM
Australia
L4staero Offline OP
L4staero  Offline OP
Australia
The 6.4 intake definitely does not seem like a restriction on this engine. Ive had it to 7400 rpm a dozen times and it never seems to have the power taper off hard.
I dont plan to spend a whole lot of time on maximising the combo but ill take it to the track a few more times and play with the cam timing once i take a little rear gear out of it
Re: Budget 5.7 Eagle build [Re: L4staero] #2723333
12/11/19 07:28 PM
12/11/19 07:28 PM
Springtown Pa
Springtown Pa
yeah those 4.88s are a bit steep for that combo, either way your making low 400hp from the combo,
1996 Viper GTS
