paint question for neubie #2722538
12/08/19 01:22 PM
12/08/19 01:22 PM
IL . usa
cjs69mope Offline OP
IL . usa
I just got done painting my car in garage , heated to 80 deg. 1230 am last night .
I need to paint more parts that i based coated yesterday
My question is how soon can I pull the car body out of the garage to cold 40 deg out side temp?
IT has been only 8 hrs since clear coated and air dry at 70-80 deg temp heat in garage .
Should I be concerned that temp change could cause a issue?
Thanks Moparts for the help.
CJ.
1969 Dodge Charger 1969 Dodge Superbee
Re: paint question for neubie [Re: cjs69mope] #2722541
12/08/19 01:29 PM
12/08/19 01:29 PM
Central Florida
larrymopar360 Online content
Stud Muffin
larrymopar360  Online Content
Stud Muffin
Central Florida
I don't think temp is your concern. It's debris, bugs, etc.getting into the paint while still tacky.
Facts are stubborn things.
Re: paint question for neubie [Re: larrymopar360] #2722545
12/08/19 01:35 PM
12/08/19 01:35 PM
IL . usa
IL . usa
it is dry dust no bugs up here now was worried about condensation due to temp change
Re: paint question for neubie [Re: cjs69mope] #2722549
12/08/19 01:42 PM
12/08/19 01:42 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I would leave it warm for at least 24 hours. I would like to see 70 degrees minimum.
Re: paint question for neubie [Re: markz528] #2722552
12/08/19 02:00 PM
12/08/19 02:00 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Patience Grasshopper. biggrin
Re: paint question for neubie [Re: cjs69mope] #2722557
12/08/19 02:17 PM
12/08/19 02:17 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
To answer the question with any certainty you really should take to the paint Mfr's rep. There are a lot of variables involved that cannot all be answered here.
My advice is to wait unless you want to do it again. frown twocents beer
Re: paint question for neubie [Re: TJP] #2722558
12/08/19 02:24 PM
12/08/19 02:24 PM
IL . usa
IL . usa
I checked the under side of rocker panel it is dry and pretty hard so i am going to drape plastic paint mask over whole car and leave inside while i spray other parts with clear that should keep over spray off and not have to bring out side shop.
very limited time got to getter done!
thanks again .
Re: paint question for neubie [Re: markz528] #2722605
12/08/19 06:24 PM
12/08/19 06:24 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Good advice.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: paint question for neubie [Re: cjs69mope] #2722615
12/08/19 07:10 PM
12/08/19 07:10 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
thanks again .
do not plastic a fresh paint job unless you want to redo it. you will get solvent pop.
Re: paint question for neubie [Re: chrisf] #2722627
12/08/19 07:51 PM
12/08/19 07:51 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Along with a variety of other potential consequences. There are some things that cannot be rushed and paint is one of them twocents
Re: paint question for neubie [Re: TJP] #2722720
12/09/19 10:48 AM
12/09/19 10:48 AM
IL . usa
IL . usa
Update , so paint on car was dry to touch and had been drying at 80 deg for 11 hrs.
Put paint mask plastic not regular plastic on car , sprayed out hood and fenders , .
Waited for over spray to get vacumed out by my home made box fan exhaust and renoved plastic.
No issues and car can stay inside and cure .
Going to wait 36 hrs and cut and buff paint recommended by my paint supply store.
Thanks .
Re: paint question for neubie [Re: cjs69mope] #2722763
12/09/19 03:19 PM
12/09/19 03:19 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Years a go a paint store counter guy told me to have it baked in a booth, or set outside on warn days as long as possible.
Cold weather paint jobs tend to be more prone to stone chips was what one of the painters on here posted once.
Re: paint question for neubie [Re: cjs69mope] #2723380
12/12/19 02:00 AM
12/12/19 02:00 AM
Kansas, USA
roadlion Offline
roadlion  Offline
Kansas, USA
Question is will it rain? That was my biggest mistake. I thought the paint is already dry. Dried it for 2 days but there was a part where it's not yet 100% dry so it rained just a little and damaged the paint. But my suggestion would be 2 days.
