paint question for neubie
#2722538
12/08/19 01:22 PM
12/08/19 01:22 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
I just got done painting my car in garage , heated to 80 deg. 1230 am last night . I need to paint more parts that i based coated yesterday My question is how soon can I pull the car body out of the garage to cold 40 deg out side temp? IT has been only 8 hrs since clear coated and air dry at 70-80 deg temp heat in garage . Should I be concerned that temp change could cause a issue? Thanks Moparts for the help. CJ.
1969 Dodge Charger
1969 Dodge Superbee
Re: paint question for neubie
[Re: cjs69mope]
#2722541
12/08/19 01:29 PM
12/08/19 01:29 PM
Posts: 15,926 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I don't think temp is your concern. It's debris, bugs, etc.getting into the paint while still tacky.
Facts are stubborn things.
[Re: larrymopar360]
#2722545
12/08/19 01:35 PM
12/08/19 01:35 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
it is dry dust no bugs up here now was worried about condensation due to temp change
1969 Dodge Charger
1969 Dodge Superbee
[Re: cjs69mope]
#2722549
12/08/19 01:42 PM
12/08/19 01:42 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
I would leave it warm for at least 24 hours. I would like to see 70 degrees minimum.
[Re: TJP]
#2722558
12/08/19 02:24 PM
12/08/19 02:24 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
I checked the under side of rocker panel it is dry and pretty hard so i am going to drape plastic paint mask over whole car and leave inside while i spray other parts with clear that should keep over spray off and not have to bring out side shop. very limited time got to getter done! thanks again .
1969 Dodge Charger
1969 Dodge Superbee
[Re: markz528]
#2722605
12/08/19 06:24 PM
12/08/19 06:24 PM
Posts: 16,519 On the run…
BloFish
On the run…
I would leave it warm for at least 24 hours. I would like to see 70 degrees minimum. Good advice.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: cjs69mope]
#2722615
12/08/19 07:10 PM
12/08/19 07:10 PM
Posts: 5,949 British Columbia
chrisf
British Columbia
I checked the under side of rocker panel it is dry and pretty hard so i am going to drape plastic paint mask over whole car and leave inside while i spray other parts with clear that should keep over spray off and not have to bring out side shop. very limited time got to getter done! thanks again . do not plastic a fresh paint job unless you want to redo it. you will get solvent pop.
[Re: TJP]
#2722720
12/09/19 10:48 AM
12/09/19 10:48 AM
Posts: 587 IL . usa
cjs69mope
IL . usa
Update , so paint on car was dry to touch and had been drying at 80 deg for 11 hrs. Put paint mask plastic not regular plastic on car , sprayed out hood and fenders , . Waited for over spray to get vacumed out by my home made box fan exhaust and renoved plastic. No issues and car can stay inside and cure . Going to wait 36 hrs and cut and buff paint recommended by my paint supply store. Thanks .
1969 Dodge Charger
1969 Dodge Superbee
