Re: 512 stroker
[Re: AndyF]
#2720967
12/02/19 06:07 PM
12/02/19 06:07 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
It would be better to state what et you expect , the track you run the most & how much the car weighs, & welcome here !!!
Re: 512 stroker
[Re: Gartho]
#2721185
12/03/19 04:09 PM
12/03/19 04:09 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Great looking ride!!
Love the new wheels!!
Does the track you go to not enforce the roll bar restrictions?
It should be nothing to have that car running way way under the 11.50 cut off.
