Vac pump breather #2720331
11/29/19 08:35 PM
11/29/19 08:35 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
For those of you that run a vac pump, how do you control the oil from coming out the breather? On start up I have 3" of vac & its regulated to 10" of vac, on full rpm. There are 2x lines with baffles that pull the air from the front of the rocker covers. Every run we get maybe a tablespoon of oil from the catch can but it always has about 2x tablespoons of oil dripping off the filter. Can anyone enlighten me on how to stop the mess I have to clean after every run?
Re: Vac pump breather [Re: rebel] #2720343
11/29/19 09:33 PM
11/29/19 09:33 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I baffled my overflow can with the stainless steel kitchen pan scrubbies. Still not perfect. Epoxied a lip under the filter so the oil would drain off it back inside. Finally cut off the tops of old socks and slid them over the filter. Wash it out every 20 passes or so.
Doug
Re: Vac pump breather [Re: dvw] #2720344
11/29/19 09:39 PM
11/29/19 09:39 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Someone taught me years ago to put a wrist sweat band around the filter. For me it works fantastic.
Example:
https://www.amazon.com/WILLBOND-Swe...+sweatband&qid=1575077954&sr=8-4
Re: Vac pump breather [Re: markz528] #2720362
11/29/19 11:13 PM
11/29/19 11:13 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
This is what I use, my motor pulls over 20” of vacuum every run, these socks work!!
Re: Vac pump breather [Re: rebel] #2720366
11/29/19 11:25 PM
11/29/19 11:25 PM
I had a long baffle welded below the vacuum pickup fitting after having the same issues on my new motor this year up I had to tie rap a rag around it at the races once this year to stop the dripping rant The old motor with a different valve cover set up never had any oil drip out of the breather, never work I use one vacuum line to the valve cover per GZ instruction with the relief valve beside it also
My motors barely have any vacuum at idle and only 5 to 6 inches revved up so the pump will go back for rebuilding this winter, I would like to see 10 to 15 inches revved up luck
Re: Vac pump breather [Re: Cab_Burge] #2720389
11/30/19 06:56 AM
11/30/19 06:56 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I see many cars with the regulator on the engine side. This means air flows through the engine drawing oil mist through. Mounting the regulator post engine will minimize flow through the engine. It's mainly water that comes out when i drain the catch can.
Re: Vac pump breather [Re: Tig] #2720491
11/30/19 06:26 PM
11/30/19 06:26 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Wrist band
Re: Vac pump breather [Re: OUTLAWSSAA] #2720910
12/02/19 03:33 PM
12/02/19 03:33 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Nothing but steam in mine. I ran it 41 passes and just drained it for the first time. A few drops of water/oil in it, maybe a tbsp. I think a lot of the large amounts of oil many see are from engine that are not sealed well or have poor oil control. FWIW I do not regulate any of mine.
Re: Vac pump breather [Re: Al_Alguire] #2720926
12/02/19 04:05 PM
12/02/19 04:05 PM
an8sec70cuda Offline
I don't have a problem w/ this either. I have a Moroso 4 vane pump and the regulator is mounted on the inlet of the pump. I use an Aerospace components catch can.
There's never much in the can, but I drain it after I get home from the track. Mostly water and a little oil.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Vac pump breather [Re: Al_Alguire] #2720975
12/02/19 06:37 PM
12/02/19 06:37 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Al, How do you run your rear main seal? I suspect mine pulls air there.
Doug
Re: Vac pump breather [Re: dvw] #2721096
12/03/19 09:25 AM
12/03/19 09:25 AM
FWIW...I run a normal Fel-Pro rear main seal installed in the normal orientation. Same w/ the front seal. Some people turn them around backwards, but I've never tried it. Same w/ the SB chevy we run.
CHIP
Re: Vac pump breather [Re: an8sec70cuda] #2721459
12/04/19 08:14 PM
12/04/19 08:14 PM
gregsdart Offline
gregsdart  Offline
I run two breathers. That along with a baffled vacuum line from the front of a valvecover. I run pushrod oiling AND spraybar oiling which puts a lot of oil mist in the motor. If you have enough pump capcity to need a vacuum regulater then you are running more air through the motor and carring mist to the pump with it. Reducing pump speed till you need little or no regulater will reduce oil coming out of the pump. I don't need a regulater to get 10 inchs of vacuum, as much as i want. Not using a regulater also makes it easier to spot problems. If the vacuum is less during a run, time to look for trouble. My last outing vacuum dropped. The pan bolts were loose. No more cork gaskets for me! I had checked them twice and the gaskets still compressed more.
Re: Vac pump breather [Re: dvw] #2721471
12/04/19 08:50 PM
12/04/19 08:50 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Doug
I am with Al, nothing but water, have 11 inches at idle, 17 downtrack, double lip seal on the rear main (fastfish), the timing chain cover seal has 2 springs and the backside was filled with RTV (cured) before being installed. If i had a Jesel belt drive it would seal better.
Joe
Without Data, you’re just another guy with an opinion.
Re: Vac pump breather [Re: sr4440] #2721574
12/05/19 07:30 AM
12/05/19 07:30 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I have a motor that I intentionally over oil through the pushrods, and use almost unrestricted spray bars as well. I did it t see how much better the spring life would be. Even with 2 pickup points on the covers it would flood the vacuum system with oil. I went to my default breather attachments, Z baffle burn down breathers that you see mostly on blown alky stuff. They're ugly, and stick way up, but even on that oil derrick all I get is water smoke.
These things are a cure all for oil geyser vacuum systems.
https://www.goodvibrationsmotorsports.com/Burndown-Breathers-Aluminum-Female-AN16.aspx
Re: Vac pump breather [Re: dthemi] #2721676
12/05/19 01:26 PM
12/05/19 01:26 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I run nothing fancy for a rear main oil seal and it is installed in the standard manner. My engine seen 19+-" of vacuum and the dragster is a tad more. These are both big stroke deals.
Re: Vac pump breather [Re: Al_Alguire] #2721827
12/05/19 08:19 PM
12/05/19 08:19 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Ill air it up and check for leaks. I see no oil leaking externally. Gets about 4oz in 25 passes
Doug
