Open chamber aluminum head #2720289
11/29/19 05:10 PM
11/29/19 05:10 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Does anyone make an open chamber BB aluminum head ??
Re: Open chamber aluminum head [Re: Stanton] #2720290
11/29/19 05:13 PM
11/29/19 05:13 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Edelbrock 88cc rpm, or you can have Indy cnc it into one of their heads.
The Ede head open chamber quench pad area is .100 deep.
Re: Open chamber aluminum head [Re: fast68plymouth] #2720340
11/29/19 09:22 PM
11/29/19 09:22 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Quote
Yikes !! I guess you don't want a piston that's down in the hole at TDC !!
Re: Open chamber aluminum head [Re: Stanton] #2720357
11/29/19 10:56 PM
11/29/19 10:56 PM
Cab_Burge Online work
Cab_Burge  Online Work
Why do you want one of them? confused
Re: Open chamber aluminum head [Re: Cab_Burge] #2720368
11/29/19 11:37 PM
11/29/19 11:37 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Not "one", two.
So here's the deal. I currently have Indy EZ1 max wedge heads and single 4 intake. My pistons sit .016 out of the hole and I have the thickest gasket I can find and still only have .035 quench. Close enough to be nervous. Now I've got a hankerin' to install efi using the Eddy Pro-flow intake BUT its made for standard ports so-o-o-o I'm thinking if I switch heads to a standard port at the same time I'd use an open chamber and solve my quench issue. But obviously with .100 its going to be far to much clearance even with a thin gasket. Yes, I suppose I could cut a brand new set of heads !!
Re: Open chamber aluminum head [Re: Stanton] #2720372
11/29/19 11:58 PM
11/29/19 11:58 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Not "one", two.
Cometic make gaskets any thickness , been running mine .016 out .051 gaskets for 9k miles no hitting the head They have .060 off the shelf
Re: Open chamber aluminum head [Re: CSK] #2720373
11/30/19 12:09 AM
11/30/19 12:09 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
a
Re: Open chamber aluminum head [Re: CSK] #2720398
11/30/19 09:52 AM
11/30/19 09:52 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Cometics are MLS and require a specific finish on the block and heads. Mine does not have that finish and everyone I've talked to (Cometic and engine builders) say they won't work properly.
Re: Open chamber aluminum head [Re: Stanton] #2720401
11/30/19 10:09 AM
11/30/19 10:09 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
would the fel-pro 1105 gasket help?
Re: Open chamber aluminum head [Re: Stanton] #2720402
11/30/19 10:11 AM
11/30/19 10:11 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Not "one", two.
The most cost effective solution to your problem which depending on how much piston to wall clearance you have, might not be a problem, is a Cometic head gasket and a trip to the machine shop with your intake to have injector bungs installed. Lots of change from that out of the price of cylinder heads and a new intake.
Depending on where your top ring is located, shaving .004 off the piston shouldn't compromise its integrity but head gaskets are still cheaper and easier.
That Proflo intake with the front mount throttle body does look cool... Your current combo has more power potential tho. shruggy
Kevin
Re: Open chamber aluminum head [Re: Twostick] #2720413
11/30/19 11:06 AM
11/30/19 11:06 AM
So. Burlington, Vt.
So. Burlington, Vt.
Does SCE not offer their Titan series of gaskets in .060 thickness?
Re: Open chamber aluminum head [Re: fast68plymouth] #2720459
11/30/19 02:51 PM
11/30/19 02:51 PM
I'm sure they do but you won't find out without calling them now (661-728-9200 after being bought, moved and merged twice in the last 5 yrs scope shruggy
I've used their copper head gaskets a bunch of times with good results, blown or N/A up
Re: Open chamber aluminum head [Re: Stanton] #2720472
11/30/19 04:33 PM
11/30/19 04:33 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Lots of people run them with the "wrong" finish as is with no problems and some do it by spraying them with Coppercote or some other sealant. Cometic doesn't recommend this but I'm sure it's more from a product liability view than reality. They have no idea how "wrong" the finish that a customer has might be so to eliminate any leaking complaints that aren't their fault, they dictate the installation procedure.
Mopar used to run shim gaskets OEM and I don't recall any specific deck finish for those. That was a metal to metal seal as well.
Kevin
Re: Open chamber aluminum head [Re: CSK] #2720478
11/30/19 05:00 PM
11/30/19 05:00 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Yes - but my "custom" thick Cometic gaskets were $400 a set! This was over 5 years ago.
Re: Open chamber aluminum head [Re: markz528] #2720479
11/30/19 05:04 PM
11/30/19 05:04 PM
So. Burlington, Vt.
So. Burlington, Vt.
.060” thick by itself doesn’t require them to be “custom” from Cometic.
Re: Open chamber aluminum head [Re: Twostick] #2720480
11/30/19 05:05 PM
11/30/19 05:05 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Quote
The tight quench has been my dilemma for a few years now and I've posted on here numerous times about the issue. Cometic has often been the suggestion but this is the FIRST time anyone has suggested the SCE ones. I think these just may be the solution to my losing sleep at night! Thanks!
Re: Open chamber aluminum head [Re: Stanton] #2720520
11/30/19 09:26 PM
11/30/19 09:26 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
one other option
mill .010 -.015 out of the head
s hould be easy to do .
not enough to hurt anything .
Re: Open chamber aluminum head [Re: calrobb2000] #2720629
12/01/19 01:30 PM
12/01/19 01:30 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
SCE has a .062 T64386
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Open chamber aluminum head [Re: HOTMOPR] #2720643
12/01/19 02:10 PM
12/01/19 02:10 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Quote
Yep ... I'm liking that !!
Re: Open chamber aluminum head [Re: Stanton] #2720656
12/01/19 03:24 PM
12/01/19 03:24 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I have been using copper for 20yrs and with studs I like to add some tq to the head stud around 5 to 10 ft lbs.
Quote
