engine paint #2720301
11/29/19 06:02 PM
11/29/19 06:02 PM
taunton, mass. 02780
moparthunder70 Offline OP
I know this is going to sound like a stupid question but here goes....about 10 years ago I had my 383 out of my Coronet and cleaned it up with engine degreaser and painted it Hemi Orange out of a spray can (High Temp Engine Paint) Shortly after that the paint peeled...a couple of years later I detailed the engine bay, removed the motor, cleaned and wire brushed it down and sprayed it again...fast foward to now..it's peeling again...in both cases High Temp Engine paint was used....help...
Re: engine paint [Re: moparthunder70] #2720307
11/29/19 06:14 PM
11/29/19 06:14 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I had the same problem with so-called "Engine Enamel" (but only once). Won't be using that crap again! rant
I too would be interested in hearing from those whose engine paint DID stay attached to the block... work
Re: engine paint [Re: DrCharles] #2720311
11/29/19 07:01 PM
11/29/19 07:01 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Did you degrease it?
I just use whatever enamel paint is at Home Depot in a color I like, I follow the directions and it lasts. Painted the 318 in my Diplomat apple green 20 years ago, still there, no peeling. But I don't have a resto car either so the correct color doesn't matter to me.
Re: engine paint [Re: DrCharles] #2720313
11/29/19 07:07 PM
11/29/19 07:07 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Never had a peeling problem, and the 1st engine I painted was in the early '70s. Oldest one I have is still fine 33 years later.
That's rattle-can engine paint, rattle-can "industrial" paint (race cars, non-OEM greys), or Bill Hirsch paint from a gun.
It's critical to start with a clean, grease-free surface.
I always use a primer with some zinc content, though others here don't prime at all.
I scuff the tin with a red Scotchbrite pad after cleaning & before priming.
Ironically, the worst "luck" I've had is with powder-coated wheels; I'll never do that again.
Re: engine paint [Re: moparthunder70] #2720314
11/29/19 07:08 PM
11/29/19 07:08 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I suspect it may not be the paint but rather the surface preparation. After cleaning and before painting, the surface should be prepped with a suitable wax and grease remover. Some brake cleaners will work as will acetone followed up with an alcohol rinse. Your local paint supplier may be able to help as well. twocents beer
Re: engine paint [Re: TJP] #2720325
11/29/19 07:47 PM
11/29/19 07:47 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I can't speak for the OP, but I definitely used Grease & Wax Remover then a rinse/wipe (think it was brake cleaner).
Yes, surface prep is usually the most common cause of paint failure, but I knew that and followed directions whistling
I suspect the machine shop sprayed some kind of gray coating or paint on the block to keep it from rusting. Where the paint has come off in big sheets, there is hardly a trace of rust underneath. Maybe I should have sanded first! shruggy
Re: engine paint [Re: DrCharles] #2720326
11/29/19 08:00 PM
11/29/19 08:00 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
It may have been exposed to some sort of contaminant like silicone ( think lubricant overspray) and that can be a real problem to get rid of, especially on a porous surface. Sanding typically would only spread it around. The only other thing I can think of would be to use a metal etch solution. beer
Re: engine paint [Re: TJP] #2720329
11/29/19 08:21 PM
11/29/19 08:21 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I use paint from www.hirschauto.com and have never had a problem. I have even brushed it on with no brush marks.
JB Rhinehart, Realist
A-Body's RULE!
Re: engine paint [Re: TJP] #2720330
11/29/19 08:30 PM
11/29/19 08:30 PM
thanks to everyone for their input on my problem...I did use an engine degreaser and wire brush and cleaned the block as best I could....I'm going to do this again but this time I'll try using the brake cleaner and wire brush...while I agree that the problem might be the prep, I did do prep work last time...maybe the third time will be the charmer..thanks again to everyone for your input...I might look into a high temp primer..
Re: engine paint [Re: moparthunder70] #2720341
11/29/19 09:30 PM
11/29/19 09:30 PM
katakan
lilred Offline
lilred  Offline
katakan
Maybe consider finishing of the cleaning using body shop quality lacquer thinner and wiping real well with clean rags before you paint, also an epoxy primer or some good quality etch primer.
Re: engine paint [Re: Rhinodart] #2720361
11/29/19 11:13 PM
11/29/19 11:13 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
I agree, I have used their paint from a rattle can and a quart, always a good result. High solids, dries fast, forgiving of my mistakes. I have it on two engines.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: engine paint [Re: lilred] #2720367
11/29/19 11:28 PM
11/29/19 11:28 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
I use to wipe the block with acetone, then wipe with muritic acid and then a dulted baking soda water wipe to neutralize the acid followed by clean water. One more wipe with acetone.
Get the block very warm to the touch and lay on light layers of color. I had a old electric wall oven that I built a sheetrocked and R19 insulated paint oven that was 4 foot cubed inside for baking parts. Set it to 150F for 1/2 hour.
All these new paint formulas are crap without the lead and other dangerous chemicals.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: engine paint [Re: Dave_J] #2720371
11/29/19 11:45 PM
11/29/19 11:45 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Hirsh paint is the best..flows nice...
https://youtu.be/NI5rdp0R15o
Re: engine paint [Re: moparthunder70] #2720447
11/30/19 02:12 PM
11/30/19 02:12 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The wire brush will likely absorb and spread any remaining contaminants into the pores of the cast iron. With the problems you have had I would strongly encourage getting a metal etch solution from the local auto paint store. Then etch prime,and paint away. Good luck beer
Re: engine paint [Re: TJP] #2720509
11/30/19 08:26 PM
11/30/19 08:26 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
After cleaning I use laquar thinner wipe it down and use etching primer. Never had a problem. Next one I do is gonna be powder coated although I know that peels after a few years I like it. I'm hoping the new stuff is better.
