what cam for bracket car #2719740
11/27/19 01:52 PM
11/27/19 01:52 PM
louisville ky
hemi6sp Offline OP
hemi6sp  Offline OP
louisville ky
Gathering parts for new build, for my 70 dart bracket car.
Building a 392 combo using a 5.7 block , 05 model year i believe.(03 to 08 this i know just not specific year)
using eagle heads, and a ritter short 4150 intake ,70 dart using cal tracks and mono leafs, 727 trans,4.56 gear, will
purchase new ultimate converter, or send current back for changes they recommend. I would like to purchase a cam before
I take heads and block to machinist, thanks
Re: what cam for bracket car [Re: hemi6sp] #2719765
11/27/19 02:54 PM
11/27/19 02:54 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
how fast you want to go? Compression? Fuel?
Re: what cam for bracket car [Re: HotRodDave] #2719775
11/27/19 03:19 PM
11/27/19 03:19 PM
louisville ky
hemi6sp Offline OP
hemi6sp  Offline OP
louisville ky
local track is 1/8th mile , wanting to run 6.80ish (10.90 1/4 mile ) ,hoping to stay away from race gas, local 93 octane, compression 11.5 to 12. thanks
Re: what cam for bracket car [Re: hemi6sp] #2719992
11/28/19 10:49 AM
11/28/19 10:49 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I just completed a similar build. If you want your heads ported contact Ray(sixpackgut) and he can order a custom cam (Comp)
for your combo at the same cost of a shelf cam. https://www.facebook.com/BornAgainHotRods/
Or contact gremlinsteve if you just need a cam.
Re: what cam for bracket car [Re: hemi6sp] #2720015
11/28/19 11:37 AM
11/28/19 11:37 AM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
My guy finished up a 392(5.7 based) last week , set of Pre Eagle heads 2.125/1.62 valves , 10.5 to one, Prefix single plane intake , HUG SER3438MHLN-10 .589/.594 234/238@50 pulled 55Xhp and 56Xtq at 3600lbs that should get you where you want to be. with good Eagles I would think it would be in the 57X+hp range.
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
