Freak Driveline Explosion #2719882
11/27/19 10:28 PM
11/27/19 10:28 PM
my own world
theraif Offline OP
theraif  Offline OP
my own world
Re: Freak Driveline Explosion [Re: theraif] #2719895
11/27/19 11:13 PM
11/27/19 11:13 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Wow!
Re: Freak Driveline Explosion [Re: theraif] #2719906
11/27/19 11:46 PM
11/27/19 11:46 PM
Cab_Burge Online work
Cab_Burge  Online Work
I wonder if he accidently stuck it into reverse?
Why did it hop a little off the starting line like he hit the throttle and then let off and then got back on the throttle again work Did he roll the sprague doing that?
Re: Freak Driveline Explosion [Re: Cab_Burge] #2719986
11/28/19 10:34 AM
11/28/19 10:34 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Wow, I don't want to say he's lucky, but that helmet saved his life!!
It sure would be interesting to find out what initiated that kind of
destruction of the driveline.
Something failed at one end or the other to twist that shaft like that.
I can't imagine the rear locking up would do that, but it looked like the tires were smoking
at the time of the explosion.
Joe
Re: Freak Driveline Explosion [Re: jlatessa] #2719988
11/28/19 10:41 AM
11/28/19 10:41 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Seriously ugly, regardless of the cause.
Re: Freak Driveline Explosion [Re: jlatessa] #2719989
11/28/19 10:42 AM
11/28/19 10:42 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
A good friend of mine was one of those guys that felt he had to shift into neutral after a pass. He totaled his car after missing neutral.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Freak Driveline Explosion [Re: pittsburghracer] #2719991
11/28/19 10:48 AM
11/28/19 10:48 AM
Minn
SportF Offline
SportF  Offline
Minn
I don't want to be in the lane next to guy that feels this is necessary.
Re: Freak Driveline Explosion [Re: pittsburghracer] #2720001
11/28/19 11:02 AM
11/28/19 11:02 AM
New York
polyspheric Offline
polyspheric  Offline
New York
The technology to prevent selecting anything but high gear and neutral with the throttle closed is 50 years old, and has like 3 moving parts.
I guess that's why it's not mandatory - it doesn't cost enough.
Boffin Emeritus
Re: Freak Driveline Explosion [Re: polyspheric] #2720005
11/28/19 11:15 AM
11/28/19 11:15 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
This is our local track.Turbo 400s have been known to explode when shifted into neutral after the run. Is this what happened? At 2:16 into the video I see the input shaft laying out . However in this case the driveshaft appears to have twisted in half. Why? Did the trans cause it? Don't know.
Doug
Re: Freak Driveline Explosion [Re: theraif] #2720011
11/28/19 11:29 AM
11/28/19 11:29 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Doubt he shifted into neutral as he wasn't past the finish line when it let go. Probably a stock 50 year old drive shaft with a million runs on it. The pic they show of it all mangled at the end looks like a fairly small diameter with mild wall thickness. Scary accident for sure.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Freak Driveline Explosion [Re: A39Coronet] #2720026
11/28/19 12:07 PM
11/28/19 12:07 PM
A727Tflite Offline
A727Tflite  Offline
Around :30 and in slow motion around :46 it looks like the car’s nose dips slightly.
I doubt the track has a dip at that point but maybe.
Re: Freak Driveline Explosion [Re: theraif] #2720034
11/28/19 12:25 PM
11/28/19 12:25 PM
PA.
"Little"John
"Little"John
PA.
That wasn’t a very fast car. Looked like a 6 something pass at best.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Freak Driveline Explosion [Re: A727Tflite] #2720035
11/28/19 12:26 PM
11/28/19 12:26 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Spend money on a good shaft and put good loops in the car that are attached to something heavier than 20ga sheet metal? Naw...I've had this stuff in the car for years and nothing has ever happened. You guys are just trying to sell me crap.
Re: Freak Driveline Explosion [Re: theraif] #2720047
11/28/19 01:18 PM
11/28/19 01:18 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Never ceases to amaze me what some people consider "entertainment". rolleyes realcrazy
Re: Freak Driveline Explosion [Re: John_Kunkel] #2720056
11/28/19 01:33 PM
11/28/19 01:33 PM
Washington
madscientist Offline
Washington
All that money spent and it looks like an OE drive shaft.
When you see a drive shaft break in the center like that you know the tube was too small in diameter and the wall thickness was too thin. And probably it was a cheap materiel.
BTDT.
Re: Freak Driveline Explosion [Re: madscientist] #2720088
11/28/19 03:01 PM
11/28/19 03:01 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Woohoo that is crazy
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Freak Driveline Explosion [Re: theraif] #2720094
11/28/19 03:29 PM
11/28/19 03:29 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Install a carbon shaft and a Reid case.
Re: Freak Driveline Explosion [Re: jim sciortino] #2720097
11/28/19 03:41 PM
11/28/19 03:41 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Word round the camp fire was that the rear locked up.......no idea as to why.
We learned the hard way about trying to use a stock drive shaft very early on.
On street tires , it spun hard into third.
When it finally hooked , it twisted the shaft in half , shelled the trans case and beat a hole in the floor behind the front seats.
The loop did it's job.
And I could see that being a contributor to this one.
It could have been so much worse.
