A/T yoke length #2719210
11/25/19 03:34 PM
11/25/19 03:34 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Hi guys,
I’m chasing down a slight driveline vibration at cruise around 65, under accel or decel it’s not there, I can accelerate up to 65 and back the throttle off to just maintain 65 and there it is, enough to vibrate the rear view mirror. I’ve updated to a D60 with 3.74 gears and had a new driveshaft made by Spicer here locally, had it back to them to re-check balance. One thing I did notice is my new 1350 trans yoke was shorter then the original E body yoke, I can grab the driveshaft and feel the yoke has some movement in the trans so the bushing is possible a little worn. But I can’t help but think the shorter yoke may not be helping, sorry I can’t recall by how much it’s shorter but from memory it’s probably about an inch maybe???.
Question is, is there different length yokes??? Can I get a long yoke for my 727??
Re: A/T yoke length [Re: crash520] #2719218
11/25/19 03:58 PM
11/25/19 03:58 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Just to follow up, the original yoke length is 6”, I’m now thinking the 1350 yoke I have is more like 4” to 4-1/2”
Re: A/T yoke length [Re: crash520] #2719290
11/25/19 08:09 PM
11/25/19 08:09 PM
Quote
Yes. I had that same issue &I kept the yoke (904) with a slightly longer shaft & it took care of it (part time vibration at various speeds, mostly decel iirc).
Re: A/T yoke length [Re: crash520] #2719291
11/25/19 08:14 PM
11/25/19 08:14 PM
Cab_Burge Online work
Cab_Burge  Online Work
I would put it up on 4 jack stands so the vehicle is level like it is driven on your roads and have someone run the throttle in gear and watch under the car what is vibrating scope twocents
Let us know what you find, that will help others on here later, hopefully luck
Re: A/T yoke length [Re: Cab_Burge] #2719298
11/25/19 08:36 PM
11/25/19 08:36 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Thanks Guys, yes Cab I’m still to do that, my dad has his car on my four post so as soon as it’s off I’m onto it, I thought I found the issue last weekend as I thought I’d take the wheels in to check the balance, both rears and one front were 45g out, the other front was 105g out, steering didn’t shake, put the wheels back on and could notice a difference.
Re: A/T yoke length [Re: RapidRobert] #2719299
11/25/19 08:37 PM
11/25/19 08:37 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Originally Posted by RapidRobert
Quote
Interesting for sure Rob
Re: A/T yoke length [Re: crash520] #2719368
11/26/19 03:03 AM
11/26/19 03:03 AM
I wouldn't try it on a lift that lets the suspension hang down, you want the weight on the suspension just like it would have sitting on the tires on the road.
In other words have the weight loading the chassis with the rear wheels off the ground so you can simulate the tires and drive train spinning like you drive it without the front tires spinning eliminating those two from the trouble shooting chain. I hope that makes since luck
Re: A/T yoke length [Re: Cab_Burge] #2719376
11/26/19 07:20 AM
11/26/19 07:20 AM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Cab, on the 4 post lift I can put the Diff on axle stands and run it under weight and at least get under the car to see what’s going on,
Re: A/T yoke length [Re: crash520] #2719461
11/26/19 01:29 PM
11/26/19 01:29 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I think the runout on the yoke is .050 at the caps and this will tell you a lot on the fit of it to the output shaft.
Re: A/T yoke length [Re: Clanton] #2719491
11/26/19 03:29 PM
11/26/19 03:29 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Saved.
Re: A/T yoke length [Re: Clanton] #2719498
11/26/19 03:46 PM
11/26/19 03:46 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Clanton, are you saying that the spec and it shouldn’t be more than that?
Pretty sure I have more
Re: A/T yoke length [Re: crash520] #2719502
11/26/19 03:57 PM
11/26/19 03:57 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Correct.That is not exact but maybe transman or dr.diff will chime in.The more ingagement on the spline with output and yoke the less it will be.I had 3.5" to 4" on mine spicer 1350
Re: A/T yoke length [Re: Clanton] #2719511
11/26/19 04:33 PM
11/26/19 04:33 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Clanton, yep finding a long barrel 1350, slip yoke is difficult, Sonnax make the longest I’ve found (thanks Cass) at 4.7” compared to the stock Mopar yoke at 6.1”, that said the bush in the trans is only like 2-1/2” long or similar, so it should be ok🤷‍♂️
Re: A/T yoke length [Re: crash520] #2720103
11/28/19 04:16 PM
11/28/19 04:16 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Update, took my drive shaft into a different place to have it high speed balanced, this time I took some measurements of the trans to Diff, spoke to the guy, he measured things up and we agree’d my driveshaft was a bit over 3/4” shorter than it could be, that with the short slip yoke meant that it it’s length was possibly more important so I’m having a new shaft made, well we will see how this one goes. I had my suspicions it was on the short side
Re: A/T yoke length [Re: crash520] #2720149
11/28/19 07:47 PM
11/28/19 07:47 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I moved my axle back 1" to make more room for a bigger tire by using a 1" spacer on the front leaf spring mount and I had to check the yoke movement.
