Re: A/T yoke length
[Re: crash520]
#2719290
11/25/19 08:09 PM
11/25/19 08:09 PM
RapidRobert
Question is, is there different length yokes??? Can I get a long yoke for my 727?? Yes. I had that same issue &I kept the yoke (904) with a slightly longer shaft & it took care of it (part time vibration at various speeds, mostly decel iirc).
Re: A/T yoke length
[Re: RapidRobert]
#2719299
11/25/19 08:37 PM
11/25/19 08:37 PM
Posts: 247 Brisbane Australia
crash520
Brisbane Australia
Question is, is there different length yokes??? Can I get a long yoke for my 727?? Yes. I had that same issue &I kept the yoke (904) with a slightly longer shaft & it took care of it (part time vibration at various speeds, mostly decel iirc). Interesting for sure Rob
Re: A/T yoke length
[Re: crash520]
#2719368
11/26/19 03:03 AM
11/26/19 03:03 AM
Posts: 43,161 Bend,OR USA
Cab_Burge
I wouldn't try it on a lift that lets the suspension hang down, you want the weight on the suspension just like it would have sitting on the tires on the road. In other words have the weight loading the chassis with the rear wheels off the ground so you can simulate the tires and drive train spinning like you drive it without the front tires spinning eliminating those two from the trouble shooting chain. I hope that makes since
Re: A/T yoke length
[Re: Clanton]
#2719498
11/26/19 03:46 PM
11/26/19 03:46 PM
crash520
Brisbane Australia
I think the runout on the yoke is .050 at the caps and this will tell you a lot on the fit of it to the output shaft. Clanton, are you saying that the spec and it shouldn’t be more than that? Pretty sure I have more
Re: A/T yoke length
[Re: crash520]
#2719502
11/26/19 03:57 PM
11/26/19 03:57 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Correct.That is not exact but maybe transman or dr.diff will chime in.The more ingagement on the spline with output and yoke the less it will be.I had 3.5" to 4" on mine spicer 1350 I think the runout on the yoke is .050 at the caps and this will tell you a lot on the fit of it to the output shaft. Clanton, are you saying that the spec and it shouldn’t be more than that? Pretty sure I have more
