4sp Trans install ?
#2719444
11/26/19 12:40 PM
11/26/19 12:40 PM
Posts: 2,092 New Mexico
JMCFAN
New Mexico
Whats the prefered method....bell housing attached to block....or transmission. have been told both....
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
Re: 4sp Trans install ?
[Re: JMCFAN]
#2719450
11/26/19 01:05 PM
11/26/19 01:05 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
Which car and motor are you wanting help on? I use to install BB in early (pre 1971) B,E and A body with the tranny attached to the bellhousing and motor, on 426 Hemi motors I would install the motor with the bellhousing and clutch installed on the motor and install the tranny from the bottom It depends on many things, some guys like to install the motors with the tranny on the K member and lower the car onto it fromm above like the factory did on the assembly lines, not me though I don't have the equipment or desire to do them that way
[Re: Cab_Burge]
#2719454
11/26/19 01:12 PM
11/26/19 01:12 PM
JMCFAN
New Mexico
Which car and motor are you wanting help on? I use to install BB in early (pre 1971) B,E and A body with the tranny attached to the bellhousing and motor, on 426 Hemi motors I would install the motor with the bellhousing and clutch installed on the motor and install the tranny from the bottom It depends on many things, some guys like to install the motors with the tranny on the K member and lower the car onto it fromm above like the factory did on the assembly lines, not me though I don't have the equipment or desire to do them that way Sorry,,,,,should have specified. 70 RR 383. Motor is in car. Trans and bellhousing out for clutch install. Car up on jackstands. Have a trans jack. Was told it can be easier to align ect with bellhousing attached to transmission
[Re: JMCFAN]
#2719508
11/26/19 04:19 PM
11/26/19 04:19 PM
Posts: 25,785 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Was told it can be easier to align ect with bellhousing attached to transmission To me, that's counterintuitive. With the bellhousing attached you have to deal with the z-bar and housing bolts. With just the trans, it's easy to stab the TO bearing and slide it in.
[Re: JMCFAN]
#2719523
11/26/19 05:48 PM
11/26/19 05:48 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
I install the bellhousing to block. Install throwout bearing, Use a bungee cord to hold fork/throwout bearing against fingers. That makes it a little less easy to knock the TOB off of the fork. Slide trans in, knock off TOB, put back on for, slide trans in......etc. Eventually it ends up in. Installing trans with bell would eliminate that, but make everything else harder
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: JMCFAN]
#2719545
11/26/19 07:55 PM
11/26/19 07:55 PM
Posts: 1,499 Slidell, LA
Plum440
Slidell, LA
Just did this on my 70 Challenger... Installed clutch and bellhousing to engine then installed the gear box. Easy if everything is lined up. I had to realign the clutch disc because it was slightly off. The alignment tool offers way too much slack in lining it up.. It looks right but 4 hrs of fighting it said other wise. Once I realigned the disc it slid straight in. Just FYI.
70 Challenger, 440, 4-speed, pLuM cRaZy 71 VW Super Beetle Convertible, Lemon Yellow A couple of Jeeps…
[Re: oldiron]
#2719556
11/26/19 08:21 PM
11/26/19 08:21 PM
JMCFAN
New Mexico
I install the bellhousing to block. Install throwout bearing, Use a bungee cord to hold fork/throwout bearing against fingers. That makes it a little less easy to knock the TOB off of the fork. Slide trans in, knock off TOB, put back on for, slide trans in......etc. Eventually it ends up in. Installing trans with bell would eliminate that, but make everything else harder I am not sure what you mean... "knock the TOB off of the fork". Last attempt i had the clutch/pressure plate aligned with tool...I think. We had it in with less then a inch to go... looks like its was hitting on the bellhousing and the lip on the trans... I did have the spring on the TOB... not sure if I should have. pulled every thing back off to check... did not have the Zbar or linkage installed at all... The struggle is real.... lol
[Re: JMCFAN]
#2719742
11/27/19 01:59 PM
11/27/19 01:59 PM
John_Kunkel
Rio Linda, CA
If you used one of the plastic disc alignment tools that come with a clutch kit, they're junk. Best disc alignment tool is a factory input shaft.
[Re: John_Kunkel]
#2719745
11/27/19 02:09 PM
11/27/19 02:09 PM
JMCFAN
New Mexico
If you used one of the plastic disc alignment tools that come with a clutch kit, they're junk. Best disc alignment tool is a factory input shaft. Wish I had one....
[Re: John_Kunkel]
#2719746
11/27/19 02:10 PM
11/27/19 02:10 PM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
That's the way I was taught to do it by my Dad. Never had a problem. And John is right on the money about using a factory input shaft. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: Cab_Burge]
#2720170
11/28/19 11:34 PM
11/28/19 11:34 PM
Posts: 5,789 Hamilton, Ontario Canada
Magnum
Same here. Assemble clutch disc and pressure plate to flywheel, then bellhousing, , throwout bearing, then transmission.
Leave the transmission in 4rth gear so you can turn the output shaft during install. It will turn the input shaft if the splines are not aligned.
As for alignment tools. These guys like a spare input shaft because they are the proper size but even the proper size will fit loose in a properly clearanced pilot bushing. So even with the proper input shaft gravity will pull it down 1/4 to 1/2". Let if fall, then raise it up. Half way between those two points is where you want it while you tighten the pressure plate bolts. With that knowledge, even a deep socket or a broom stick will perfectly center it everytime.
