Page 2 of 3 1 2 3
Re: Will this stock stroke 440 make 700hp? [Re: pittsburghracer] #2718767
11/24/19 12:09 AM
11/24/19 12:09 AM
USA
Jonny440 Offline OP
Jonny440  Offline OP
USA
Planning on c16
Re: Will this stock stroke 440 make 700hp? [Re: AndyF] #2718768
11/24/19 12:18 AM
11/24/19 12:18 AM
USA
Jonny440 Offline OP
Jonny440  Offline OP
USA
I’m probably going to advance the cam a couple degrees
Re: Will this stock stroke 440 make 700hp? [Re: Jonny440] #2718769
11/24/19 12:20 AM
11/24/19 12:20 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
4 degrees usually works great for me and I would hate your fuel bill. Lol. Why not alcohol
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Will this stock stroke 440 make 700hp? [Re: pittsburghracer] #2718770
11/24/19 12:27 AM
11/24/19 12:27 AM
USA
Jonny440 Offline OP
Jonny440  Offline OP
USA
I have no experience with that stuff
Re: Will this stock stroke 440 make 700hp? [Re: pittsburghracer] #2718774
11/24/19 12:46 AM
11/24/19 12:46 AM
USA
Jonny440 Offline OP
Jonny440  Offline OP
USA
I think if I advance it the cam should work okay
Re: Will this stock stroke 440 make 700hp? [Re: Jonny440] #2718803
11/24/19 10:01 AM
11/24/19 10:01 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
A friend ran a 440" with a similar cam in his 3000lb GTX. Had -1 heads,11.5-1 on alcohol.Never dynoed. Ran 6.20s, left very lazy. Swapped to a 268 duration cam went 5.95 1st time out. Raised the launch rpm and bent the front suspension coming down from a huge wheel stand on the next pass.
Doug
Re: Will this stock stroke 440 make 700hp? [Re: Jonny440] #2718867
11/24/19 02:09 PM
11/24/19 02:09 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Use at least 3/8" diameter x 0.120" wall pushrods.
Seems like alot of duration on the cam, but it sounds like the engine is going to rev over 7,000 RPM?
Make sure the heads have the long / deep thread inserts for the rocker shaft studs. On my first set of MW victors (early castings), I broke the center rocker shaft stand on both heads.
We modified the rocker stands by milling off the original stands and using the MW type rocker stand blocks which also allowed up to adjust the rocker shaft height.
My second set of MW Victors had longer thread inserts in the rocker stands which should be better, but not wanting to take chances, we converted that head over to use the billet aluminum MW style rocker shaft stand blocks.
Not sure if you already have the rocker arms, but now you can get a paired rocker 5/8" shaft rocker arm system that should be more stable (less flexing) than the single shaft rocker arm system.
Should make 700+ HP, but watch the High RPM power curve for valve train stability issues.
Re: Will this stock stroke 440 make 700hp? [Re: 451Mopar] #2718928
11/24/19 05:00 PM
11/24/19 05:00 PM
USA
Jonny440 Offline OP
Jonny440  Offline OP
USA
Did your buddy have his cam advanced any?
Re: Will this stock stroke 440 make 700hp? [Re: Jonny440] #2718957
11/24/19 06:38 PM
11/24/19 06:38 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I believe it was 4 advanced.
Doug
Re: Will this stock stroke 440 make 700hp? [Re: dvw] #2719013
11/24/19 09:43 PM
11/24/19 09:43 PM
USA
Jonny440 Offline OP
Jonny440  Offline OP
USA
Well I have a 4.30 gear in the back still debating on tire size 28-29.5 but I’m sure I could get it to leave with a smaller tire having more gear but don’t know if I would run out of rpm up top
Re: Will this stock stroke 440 make 700hp? [Re: Jonny440] #2719068
11/25/19 02:23 AM
11/25/19 02:23 AM
the quickest and best way to find out is to go run it up scope
Re: Will this stock stroke 440 make 700hp? [Re: Jonny440] #2719260
11/25/19 06:31 PM
11/25/19 06:31 PM
Idaho
LaRoy Engines Offline
Idaho
I have a 446 I’m putting together currently and want to see what you guys think it will make horsepower wise
10.700 deck
3.75 crank
7.100 rod
14.5:1 .030 dome piston
Eddy m/w victor Cnc port heads 332 cc 2.25 int 1.81 exh
Heads flow 375 at .750 lift
.705 lift cam 282/292 110 centerline
PAC 1225 springs
1.6 rockers
Eddy super victor intake
1050 dominator
Single line external oil pickup
I really think it should. This 451 consistently made 750+ hp on unleaded pump gas.
750+ horsepower 451
Re: Will this stock stroke 440 make 700hp? [Re: LaRoy Engines] #2719268
11/25/19 07:09 PM
11/25/19 07:09 PM
PA.
"Little"John
"Little"John
PA.
10.700 deck
3.75 crank
7.100 rod
PAC 1225 springs
1.6 rockers
1050 dominator
750+ horsepower 451
The motor now sits in a storage room. Lol. Another dyno queen story.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Will this stock stroke 440 make 700hp? [Re: pittsburghracer] #2719279
11/25/19 07:33 PM
11/25/19 07:33 PM
USA
Jonny440 Offline OP
Jonny440  Offline OP
USA
I actually just talked to a friend of mine that makes custom grind cams and he’s Going to do one up for me 272 /282 at 50 700 lift 110 centerline
Re: Will this stock stroke 440 make 700hp? [Re: pittsburghracer] #2719297
11/25/19 08:33 PM
11/25/19 08:33 PM
Idaho
Idaho
10.700 deck
3.75 crank
7.100 rod
PAC 1225 springs
1.6 rockers
1050 dominator
750+ horsepower 451
Pittsburgh-guy, You have pretty decent resume. I'm no fancy racer and I now live on Social Security. I'm just a backyard engine mechanic who can't even afford to go racing. But in 2009 I was pretty proud of what my son and I did in an unheated two car garage and a master bedroom turned into a clean room for assembly. To this day I'm still proud of it.
In 2004 my son brought me the Dec.1982 Popular Hot Rodding magazine that had an article on a 440 that his grandpa built and said, "Hey, Pop did this back in '82, can't we do something like it?" I told him we needed cylinder heads. He got out his grandpa's old flow bench and began destroying cylinder heads, had a pallet of ruined ones when he brought me a set of iron 452's. They were good enough for us to make 621 HP and 588 LB-FT on pump gas with our first 451 engine. It went into the '71 Road Runner and drove around on the street for awhile. Eventually it made 554 RWHP with 906 iron heads using the same shortblock we used in all the dyno contests. When doing some tests for a contest, where we built a 500 wedge, the 451 made 694 flywheel horsepower @ 9.7:1 compression with 906 iron heads.
We entered the 2009 dyno contest held at Comp Cams because we were head hunting Indy Cylinder Heads. The year before the spec heads were Indy heads (SR I believe) and they let Indy Cylinder Heads enter the contest with their own heads. Guess who won? I thought that was kinda corny and so we entered the next year hoping Indy was going to be there again. No such luck. I guess they weren't interested to see how much power they could make with the spec'd Edelbrock RPM head for that year. Our "queen" made 135 HP more than the next closest 451 and only 1 HP less that the highest horsepower engine in the contest, a 500ci engine.
In it's lifetime so far the "dyno queen" probably made some 200+ pulls from the first to the last with approximately 50 pulls over 700 HP. It now rests in the 1/2 ton 4x4 shop truck with 452 iron heads and de-tuned to 580 horsepower. "Dyno Queen"? I'm proud of our Dyno King!
Re: Will this stock stroke 440 make 700hp? [Re: LaRoy Engines] #2719300
11/25/19 08:39 PM
11/25/19 08:39 PM
PA.
"Little"John
"Little"John
PA.
It still comes down to the numbers at the track. We all know numbers on a flowbench or DYNO have been know to lie a little with a tweek here or a tweek there. The interwebs and RAGAZINES are full of high horsepower numbers till the rubber hits the pavement.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Will this stock stroke 440 make 700hp? [Re: pittsburghracer] #2719327
11/25/19 09:55 PM
11/25/19 09:55 PM
The Great White North
RAMM Offline
RAMM  Offline
It still comes down to the numbers at the track. We all know numbers on a flowbench or DYNO have been know to lie a little with a tweek here or a tweek there. The interwebs and RAGAZINES are full owf high horsepower numbers till the rubber hits the pavement.
Man you're rough PR. The OP asked if his high comp 440 would top 700 hp. Mr.LaRoy stated it should based on his experience. Many others offered their opinion. No et goal was stated by OP.
A little off topic but I wish jerks like you had a pair enough to throw your hat in the ring of an engine contest.(But you never would) You should win easily with your flow bench developed La eddys. Oh wait you just poo pooed flowbenches. Then again your flowbench never lies does it? Just everyone else's.
I bet you would have a whole different outlook on things. But alas, you are just an old guy that has a flyweight , very well sorted chassis that would run in the 11's with a stock 318 out of a '81 Mirada. Give yourself a big pat on the back. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Will this stock stroke 440 make 700hp? [Re: LaRoy Engines] #2719363
11/26/19 01:53 AM
11/26/19 01:53 AM
AndyF Offline
AndyF  Offline
10.700 deck
3.75 crank
7.100 rod
PAC 1225 springs
1.6 rockers
1050 dominator
750+ horsepower 451
Dyno King is a good name for that engine. That was a good one. I was never able to get within sniffing distance of 700 hp with Edelbrock heads. I don't think I ever got much over 600 hp with any of my RPM headed engines. Once the Trick Flow heads came out I was able to make 700+ pretty easily. Your set of Edelbrock heads were definitely a high water mark. That engine really knocked them over at the EM.
Re: Will this stock stroke 440 make 700hp? [Re: Jonny440] #2719394
11/26/19 09:42 AM
11/26/19 09:42 AM
an8sec70cuda Offline
10.700 deck
3.75 crank
7.100 rod
PAC 1225 springs
1.6 rockers
1050 dominator
FWIW I would expect this thing to pretty easily make 700 hp. It's not going to be a low rpm grunt motor by any means though.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Will this stock stroke 440 make 700hp? [Re: an8sec70cuda] #2719412
11/26/19 10:58 AM
11/26/19 10:58 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
With a 5,000 Stall converter who cares about low end grunt smile
Page 2 of 3 1 2 3
