Re: Heads
[Re: cesar perez]
#2718289
11/22/19 01:16 AM
11/22/19 01:16 AM
Posts: 43,185 Bend,OR USA
Cab_Burge
Between edeldrock Indy trickflow what's and steath what is the best head for the money You know the answer, it depends of course on what power are you want to make If you want to make 500 HP with a stock stroke 440 the Stealths are your answer, If you wanting to make 700+ HP with a stock stroke 440 the B1 or better(maybe a good set of ported440-1 with multiple carbs) are your best solution
Re: Heads
[Re: BigBlockGTS]
#2718404
11/22/19 02:17 PM
11/22/19 02:17 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Depends on what you are trying to do. A race set up? street cruiser? Exactly. TF’s are a great value if they’ll work for what you’re trying to build. But if you’re trying to build a 1000hp 572...... it doesn’t matter how good of a value that are....... they’re the wrong choice.
Re: Heads
[Re: dart9ss]
#2719619
11/27/19 12:51 AM
11/27/19 12:51 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
As said, depends on what you’re trying to do. 10 years ago I was trying to build a street strip car that would go 11.50’s, and I was on a thin budget. I bought a set of Stealths.... today the car has gone into the 11-teens with the same heads, so they were a great value for me.
