Heads #2718254
11/21/19 10:33 PM
11/21/19 10:33 PM
florida dade
cesar perez Offline OP
florida dade
Between edeldrock Indy trickflow what's and steath what is the best head for the money
Re: Heads [Re: cesar perez] #2718265
11/21/19 11:18 PM
11/21/19 11:18 PM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
Depends on what you are trying to do. A race set up? street cruiser?
Re: Heads [Re: cesar perez] #2718279
11/22/19 12:17 AM
11/22/19 12:17 AM
USA
Jonny440 Offline
Jonny440  Offline
USA
I got eddys nothing wrong with some good old 906s
Re: Heads [Re: cesar perez] #2718289
11/22/19 01:16 AM
11/22/19 01:16 AM
You know the answer, it depends of course on what power are you want to make work
If you want to make 500 HP with a stock stroke 440 the Stealths are your answer, If you wanting to make 700+ HP with a stock stroke 440 the B1 or better(maybe a good set of ported440-1 with multiple carbs) are your best solution work twocents
Re: Heads [Re: Cab_Burge] #2718385
11/22/19 01:28 PM
11/22/19 01:28 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
INDY SR my twocents
Re: Heads [Re: BigBlockGTS] #2718404
11/22/19 02:17 PM
11/22/19 02:17 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Exactly.
TF’s are a great value if they’ll work for what you’re trying to build.
But if you’re trying to build a 1000hp 572...... it doesn’t matter how good of a value that are....... they’re the wrong choice.
Re: Heads [Re: fast68plymouth] #2719603
11/27/19 12:03 AM
11/27/19 12:03 AM
nj pine beach
dart9ss Offline
dart9ss  Offline
nj pine beach
I run a set of S/R s ported by Dwayne, 660 lift, intake port matched ,14 to 1 at 2785lbs best 9.01 147. low maintenance and fun to drive.
Re: Heads [Re: dart9ss] #2719619
11/27/19 12:51 AM
11/27/19 12:51 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
As said, depends on what you’re trying to do. 10 years ago I was trying to build a street strip car that would go 11.50’s, and I was on a thin budget. I bought a set of Stealths.... today the car has gone into the 11-teens with the same heads, so they were a great value for me.
