Making some progress, 68 gtx clone
#2717960
11/20/19 11:33 PM
11/20/19 11:33 PM
Posts: 866 Missouri
galen
Missouri
Weekend warrior/ cruise night and occasional track car. With some health issues behind me I am back up and working at almost 62 years young.. Been in a wheelchair for 20 years so my shop is set up accordingly. Benches, engine stands all lowered. Plus heat, air, satellite dish. Do all my own work, just a little different, LOL. I drive with hand controls (throttle and brakes). So after previous car learning curves this one will be built solely with that in mind. Easy for me to work on, programmable shifting, tuning, better brakes, etc. And vintage air, I'm tired of sweating. Rear suspension. Parallel 4 bar from control freak with Viking double adjustable coil overs. Mini tubs to frame rails. Ford 9 inch aluminum center section, Eaton Truetrac 3.70 gears. Wilwood 12.19 brakes. Frame connectors, torque boxes, core support brace and hidden inner fender supports.. Front suspension Gerst with power rack and pinion. Double adjustable coil overs, sway bar and 2 inch drop spindles. 12.19 brakes. Trans is a TCI 6X set up with Chrysler Reid bellhousing, 3500 stall and electronic shifting. Engine will be 572 all aluminum hemi. Finally collected everything but pushrods. Got my new KB block last month. (it was worth the wait, Very stout piece.) Pump gas 11.5 to 1. Molnar crank and rods. Diamond pistons. I have both a Charley's pan and a Milodon road race pan. Leaning towards the Milodon. with a 2 quart accumulator. Heads are Stage V customs CNC ported from FHO. Stage V rockers with FHO stands. Cam is a bullet 262/270 @ .050. 114lsa, .710 in. .690 ex. Jesel lifters and belt drive. Stage V dual 4500 intake machined for injectors and rails.. Complete Holley Dominator EFI setup from Rich Nedbal. with dual 1200cfm accufab throttle bodies. Holley injectors, Holley smart coils. All wiring harnesses. Andy F throttle linkage, cam sync ,tone wheel and pickup bracket. Aeromotive Phantom 340 pump. Rich will help me on the tuning. This will be a learning curve for me. At this time I just finished rear brakes, moving to front and installing all brake lines. Then on to fuel lines and wiring. If interested I will post pics as I progress.
Re: Making some progress, 68 gtx clone
[Re: galen]
#2717978
11/21/19 01:27 AM
11/21/19 01:27 AM
Posts: 6,409 Heaven
EvilB1Dart
Heaven
Dang! That's going to be a nice piece when you're done! Looks really good. Keep at it.
"Any fool can know. The point is to understand"
- A. Einstein
[Re: varunner]
#2718054
11/21/19 11:45 AM
11/21/19 11:45 AM
Posts: 13,516 Marion, South Carolina [><]
an8sec70cuda
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: powertrip]
#2718228
11/21/19 09:17 PM
11/21/19 09:17 PM
Posts: 866 Missouri
galen
Missouri
Beautiful car, what size wheels and tires? Rear tires are M&H 325/45R-17 28 in. tall on a 17x12. I have enough room for a 13 maybe even a 14in. wheel and a 390/40-17. Fronts are 26x6x17 MT sportsmans on 17x4.5. I would like to have another set of wider fronts and maybe 10 inch rears for highway handling.
[Re: Jonny440]
#2718293
11/22/19 01:29 AM
11/22/19 01:29 AM
Posts: 43,838 Bend,OR USA
Cab_Burge
Nice love the modern hemi! Me thinks that block is not a gen 3 hemiroid motor Looks a lot like a aluminum KB 426 hemi block to me
[Re: 340Cuda]
#2718699
11/23/19 05:24 PM
11/23/19 05:24 PM
Superfreak
Superfreak
I like that block..........a lot!!
[Re: galen]
#2769261
04/28/20 08:32 PM
04/28/20 08:32 PM
Posts: 10,625 Rittman Ohio
fourgearsavoy
Rittman Ohio
Very nice high end build What ignition are you going to use ? MSD type deal or EFI ecu based system. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: galen]
#2769417
04/29/20 11:09 AM
04/29/20 11:09 AM
Posts: 3,298 West Coast, USA
jbc426
West Coast, USA
Wow, you do great work! What type of exhaust cutouts are those?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
