Making some progress, 68 gtx clone #2717960
11/20/19 11:33 PM
11/20/19 11:33 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Weekend warrior/ cruise night and occasional track car. With some health issues behind me I am back up and working at almost 62 years young.. Been in a wheelchair for 20 years so my shop is set up accordingly. Benches, engine stands all lowered. Plus heat, air, satellite dish. Do all my own work, just a little different, LOL. I drive with hand controls (throttle and brakes). So after previous car learning curves this one will be built solely with that in mind. Easy for me to work on, programmable shifting, tuning, better brakes, etc. And vintage air, I'm tired of sweating. Rear suspension. Parallel 4 bar from control freak with Viking double adjustable coil overs. Mini tubs to frame rails. Ford 9 inch aluminum center section, Eaton Truetrac 3.70 gears. Wilwood 12.19 brakes. Frame connectors, torque boxes, core support brace and hidden inner fender supports.. Front suspension Gerst with power rack and pinion. Double adjustable coil overs, sway bar and 2 inch drop spindles. 12.19 brakes. Trans is a TCI 6X set up with Chrysler Reid bellhousing, 3500 stall and electronic shifting. Engine will be 572 all aluminum hemi. Finally collected everything but pushrods. Got my new KB block last month. (it was worth the wait, Very stout piece.) Pump gas 11.5 to 1. Molnar crank and rods. Diamond pistons. I have both a Charley's pan and a Milodon road race pan. Leaning towards the Milodon. with a 2 quart accumulator. Heads are Stage V customs CNC ported from FHO. Stage V rockers with FHO stands. Cam is a bullet 262/270 @ .050. 114lsa, .710 in. .690 ex. Jesel lifters and belt drive. Stage V dual 4500 intake machined for injectors and rails.. Complete Holley Dominator EFI setup from Rich Nedbal. with dual 1200cfm accufab throttle bodies. Holley injectors, Holley smart coils. All wiring harnesses. Andy F throttle linkage, cam sync ,tone wheel and pickup bracket. Aeromotive Phantom 340 pump. Rich will help me on the tuning. This will be a learning curve for me. At this time I just finished rear brakes, moving to front and installing all brake lines. Then on to fuel lines and wiring. If interested I will post pics as I progress.
Re: Making some progress, 68 gtx clone [Re: galen] #2717963
11/20/19 11:52 PM
11/20/19 11:52 PM
AndyF Offline
AndyF  Offline
Good looking car. That is going to be a huge project so good luck and keep plugging away. If you were local I'd swing by one day a week to help you out.
Re: Making some progress, 68 gtx clone [Re: galen] #2717966
11/21/19 12:30 AM
11/21/19 12:30 AM
Alberta,Canada
605ply Offline
605ply  Offline
Alberta,Canada
love the car.... bow
Re: Making some progress, 68 gtx clone [Re: 605ply] #2717972
11/21/19 01:00 AM
11/21/19 01:00 AM
NW Indiana
P
powertrip Offline
powertrip  Offline
P
NW Indiana
Beautiful car, what size wheels and tires?
Re: Making some progress, 68 gtx clone [Re: galen] #2717978
11/21/19 01:27 AM
11/21/19 01:27 AM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Dang! That's going to be a nice piece when you're done! Looks really good. Keep at it.
"Any fool can know. The point is to understand"
- A. Einstein
Re: Making some progress, 68 gtx clone [Re: galen] #2717994
11/21/19 06:13 AM
11/21/19 06:13 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
And at the age of 62 up...…….I been on the list now for almost one year. You are a few years older than me. i'm trying to hold on to this KB block deal but don't no how long, so far there's been nothing but blah
Re: Making some progress, 68 gtx clone [Re: racerx] #2717995
11/21/19 06:15 AM
11/21/19 06:15 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Very nice. enjoy the build.
Doug
Re: Making some progress, 68 gtx clone [Re: galen] #2718019
11/21/19 09:44 AM
11/21/19 09:44 AM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
Wow, that is an awesome combo. Hat's off for your effort. Hope it works out exactly as planned. Enjoy the ride !
Re: Making some progress, 68 gtx clone [Re: varunner] #2718053
11/21/19 11:45 AM
11/21/19 11:45 AM
my own world
theraif Offline
theraif  Offline
my own world
Re: Making some progress, 68 gtx clone [Re: varunner] #2718054
11/21/19 11:45 AM
11/21/19 11:45 AM
an8sec70cuda Offline
Very nice!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Making some progress, 68 gtx clone [Re: powertrip] #2718228
11/21/19 09:17 PM
11/21/19 09:17 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Rear tires are M&H 325/45R-17 28 in. tall on a 17x12. I have enough room for a 13 maybe even a 14in. wheel and a 390/40-17. Fronts are 26x6x17 MT sportsmans on 17x4.5. I would like to have another set of wider fronts and maybe 10 inch rears for highway handling.
Re: Making some progress, 68 gtx clone [Re: galen] #2718248
11/21/19 10:11 PM
11/21/19 10:11 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
That looks awesome
68 Barracuda Formula S 340
Re: Making some progress, 68 gtx clone [Re: galen] #2718281
11/22/19 12:21 AM
11/22/19 12:21 AM
USA
Jonny440 Offline
Jonny440  Offline
USA
Nice love the modern hemi!
Re: Making some progress, 68 gtx clone [Re: Jonny440] #2718293
11/22/19 01:29 AM
11/22/19 01:29 AM
Me thinks that block is not a gen 3 hemiroid motor shruggy
Looks a lot like a aluminum KB 426 hemi block to me work
Re: Making some progress, 68 gtx clone [Re: Cab_Burge] #2718357
11/22/19 11:56 AM
11/22/19 11:56 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
That is a very impressive build.
Lot's of respect from me on this one.
Keep up the good work and keep us posted.
Re: Making some progress, 68 gtx clone [Re: 340Cuda] #2718699
11/23/19 05:24 PM
11/23/19 05:24 PM
Superfreak
Superfreak
I like that block..........a lot!!
Re: Making some progress, 68 gtx clone [Re: ] #2718731
11/23/19 08:07 PM
11/23/19 08:07 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Wow, good on ya, and I 2nd AndyF's thoughts...
Re: Making some progress, 68 gtx clone [Re: an8sec70cuda] #2766000
04/19/20 03:54 PM
04/19/20 03:54 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Been getting a little more done on the mockup. Shortened steering column to make valve cover removal a little easier. Gerst front end is done. Headers in. Making smart coil brackets. Hoping to start plumbing this week, fuel and brake lines. Slow process, but plugging away
IMG_20200415_195626080.jpgIMG_20200418_201956508.jpgIMG_20200411_152537390.jpgIMG_20200416_203818150.jpg
Re: Making some progress, 68 gtx clone [Re: galen] #2769261
04/28/20 08:32 PM
04/28/20 08:32 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Very nice high end build bow What ignition are you going to use ? MSD type deal or EFI ecu based system.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Making some progress, 68 gtx clone [Re: galen] #2769417
04/29/20 11:09 AM
04/29/20 11:09 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Wow, you do great work! What type of exhaust cutouts are those?
