70 Roadrunner power steering hose help? #2717909
11/20/19 07:35 PM
11/20/19 07:35 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
This shouldnt be that difficult but I've bought a few hoses now and none of them will work to replace the leaking hose.
Does anyone have a part number for this power steering hose? All the ones listed on RockAuto have different ends.
Thanks Guys!!!
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: 70 Roadrunner power steering hose help? [Re: 69dart] #2717917
11/20/19 08:01 PM
11/20/19 08:01 PM
Lansing, MI
70gtx440dana Online content
70gtx440dana  Online Content
Lansing, MI
Here is the one I purchased for my 70 Charger 440 with Saginaw pump: Link
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70 Roadrunner power steering hose help? [Re: 70gtx440dana] #2717922
11/20/19 08:33 PM
11/20/19 08:33 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
Yeah - I think that may have been one of the ones that we tried
If you look close - It has different ends on it.
I'm not sure what the previous owner used for this hose?
I think I need one of these adapters for the new hose - Mopar Saginaw Power Steering Fitting Adapter 5/8"-18 To -6A.
Does that sound right?
68 Dart - 340
66 Belvedere - 400
Re: 70 Roadrunner power steering hose help? [Re: 69dart] #2717944
11/20/19 10:25 PM
11/20/19 10:25 PM
VA
dragon slayer Offline
VA
What end not fitting? I assume the end into the steering gear. Does the steering gear have an adapter on it? That is a separate part.
Re: 70 Roadrunner power steering hose help? [Re: dragon slayer] #2718001
11/21/19 07:23 AM
11/21/19 07:23 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
The bottom picture looks right to me. I just bought one from O’riellys for a customer. That fitting stays in the pump normally. Looks like you are missing that fitting. I have an NOS 70 a body hose that looks like it has the same ends as the one you currently have. Maybe they don’t use the fitting in the pump.
Re: 70 Roadrunner power steering hose help? [Re: 69dart] #2718033
11/21/19 10:37 AM
11/21/19 10:37 AM
Lansing, MI
Lansing, MI
That fitting is part of the steering gear assembly. It is installed using a small brass/copper washer to seal against steering gear. Make sure you have the correct washer. I have some of them.... if you are needing one PM me. Joe
Re: 70 Roadrunner power steering hose help? [Re: 70gtx440dana] #2718035
11/21/19 10:40 AM
11/21/19 10:40 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Is it a original mopar hose? If so, it should have numbers stamped in the metal end. It kinda looks like a 2891730.
https://www.ebay.com/itm/for-MOPAR-...aw-A-B-C-E-Body-318-340-440/323859825824
Re: 70 Roadrunner power steering hose help? [Re: mopars4ever] #2718172
11/21/19 06:44 PM
11/21/19 06:44 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
No clue if its original. We bought the car last year and have spent the past year undoing lots of duckery. The only numbers I can find are 336-1005a and 322-0.
It sure look like the one you posted though https://www.ebay.com/itm/for-MOPAR-...aw-A-B-C-E-Body-318-340-440/323859825824
Awesome!!!
68 Dart - 340
66 Belvedere - 400
Re: 70 Roadrunner power steering hose help? [Re: 69dart] #2718450
11/22/19 07:41 PM
11/22/19 07:41 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
You might go to rock auto or the local parts store and check the hose for the applications listed on the ebay ad
I just did and they have the end your looking for from several sources a lot cheaper whistling
ROCK AUTO LINK WITH PIC"S
It would appear the root cause is probably the wrong pump from a later model
beer
Re: 70 Roadrunner power steering hose help? [Re: TJP] #2718677
11/23/19 03:44 PM
11/23/19 03:44 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
anyplace around you that makes hydraulic hoses? Many tractor dealerships cna do this as well.
1981 Dodge D150 360 auto
