Re: 70 Roadrunner power steering hose help?
[Re: 69dart]
#2717917
11/20/19 08:01 PM
11/20/19 08:01 PM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
Here is the one I purchased for my 70 Charger 440 with Saginaw pump: Link
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 69dart]
#2718033
11/21/19 10:37 AM
11/21/19 10:37 AM
70gtx440dana
Lansing, MI
Yeah - I think that may have been one of the ones that we tried
If you look close - It has different ends on it.
I'm not sure what the previous owner used for this hose?
I think I need one of these adapters for the new hose - Mopar Saginaw Power Steering Fitting Adapter 5/8"-18 To -6A.
Does that sound right?
That fitting is part of the steering gear assembly. It is installed using a small brass/copper washer to seal against steering gear. Make sure you have the correct washer. I have some of them.... if you are needing one PM me. Joe
[Re: 69dart]
#2718450
11/22/19 07:41 PM
11/22/19 07:41 PM
Posts: 15,299 Omaha Ne
TJP
Omaha Ne
You might go to rock auto or the local parts store and check the hose for the applications listed on the ebay ad I just did and they have the end your looking for from several sources a lot cheaper ROCK AUTO LINK WITH PIC"SIt would appear the root cause is probably the wrong pump from a later model
[Re: TJP]
#2718677
11/23/19 03:44 PM
11/23/19 03:44 PM
Posts: 7,831 east side of Ohio
basketcase
east side of Ohio
anyplace around you that makes hydraulic hoses? Many tractor dealerships cna do this as well.
1981 Dodge D150 360 auto
