1999 dodge ram abs brake problem #2717636
11/19/19 06:57 PM
11/19/19 06:57 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
I have a 1999 dodge ram 1500 5.9 gas automatic 62000 miles . having a brake problem with it. driving down the road brakes work fine . But if I roll up to a stop sign slowly the pedal seems to go to the floor and feels like the antilock is working basically wont stop anyone else have this happen?
Re: 1999 dodge ram abs brake problem [Re: 3wracing] #2717663
11/19/19 08:19 PM
11/19/19 08:19 PM
Guitar Jones Online laugh2
Sounds like the ABS module/hydraulic assembly is bad. I've seen that before.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 1999 dodge ram abs brake problem [Re: Guitar Jones] #2717683
11/19/19 09:06 PM
11/19/19 09:06 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
Tje abs module is where? The other thing is the part with all the0 brake lines?i guess?
Re: 1999 dodge ram abs brake problem [Re: 3wracing] #2717736
11/19/19 11:46 PM
11/19/19 11:46 PM
Chicago, IL
moe318 Offline
moe318  Offline
Chicago, IL
My 99 2500 had a bad sensor on the front wheel hub/bearing assembly. Would fake the computer into thinking it was on ice. Pedal to floor and rolled 1 stop sign. Lucky I was a block from the house. F ing ABS junk.
Re: 1999 dodge ram abs brake problem [Re: 3wracing] #2717760
11/20/19 04:28 AM
11/20/19 04:28 AM
It's all one unit.
Re: 1999 dodge ram abs brake problem [Re: Guitar Jones] #2717768
11/20/19 07:27 AM
11/20/19 07:27 AM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
I often wandered how do they bleed all that? powerbleed it?
Re: 1999 dodge ram abs brake problem [Re: 3wracing] #2717810
11/20/19 11:06 AM
11/20/19 11:06 AM
I would bleed the unit first one line at a time then bleed the rest of the brakes normally. A pressure bleeder would certainly make it easier.
Re: 1999 dodge ram abs brake problem [Re: 3wracing] #2717840
11/20/19 01:13 PM
11/20/19 01:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Any warning lights?
Re: 1999 dodge ram abs brake problem [Re: John_Kunkel] #2717856
11/20/19 03:07 PM
11/20/19 03:07 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
Nope
Re: 1999 dodge ram abs brake problem [Re: 3wracing] #2717858
11/20/19 03:17 PM
11/20/19 03:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What happens if you pump the brake pedal?
Re: 1999 dodge ram abs brake problem [Re: stumpy] #2717889
11/20/19 06:04 PM
11/20/19 06:04 PM
massachusetts
X
xs29l9g Offline
xs29l9g  Offline
X
massachusetts
I would suspect a wheel speed sensor cutting out. common to fail at lower speeds cause theyre workin harder. do you feel pedal vibrate like an abs activation?
Re: 1999 dodge ram abs brake problem [Re: xs29l9g] #2717905
11/20/19 07:23 PM
11/20/19 07:23 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
it pulsates when it does it. leave off brakes step back down its fine. no lights or any thing. if I pull the abs fuse it works fine but then I have to deal with the check engine light.is their a way to check the sensors at the wheels?
Re: 1999 dodge ram abs brake problem [Re: xs29l9g] #2717906
11/20/19 07:24 PM
11/20/19 07:24 PM
A wheel speed sensor would typically set a code.
Re: 1999 dodge ram abs brake problem [Re: Guitar Jones] #2718006
11/21/19 07:41 AM
11/21/19 07:41 AM
massachusetts
X
xs29l9g Offline
xs29l9g  Offline
X
massachusetts
alot of times it wont set a code, occurrence is too brief. very common on gm's also. pull the abs fuse or set a hard code(so abs light is on) and see if problem goes away. or if you have access to a scan tool , can sometimes see it happen in whl speed data. just creep along at very low speed(5-9 mph) problem sensor will not match others if 4wheel abs, or will see it drop out. note, some systems don't drop lower than 3mph in scan data, I cant recall if its gm or mopar
Re: 1999 dodge ram abs brake problem [Re: xs29l9g] #2718173
11/21/19 06:45 PM
11/21/19 06:45 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
I pull the fuse the problem voes away
Re: 1999 dodge ram abs brake problem [Re: 3wracing] #2718425
11/22/19 05:07 PM
11/22/19 05:07 PM
massachusetts
X
xs29l9g Offline
xs29l9g  Offline
X
massachusetts
yeah, I would speculate a wheel speed sensor. next step would be identify which one. that will require seein scan data. if you want to guess at it,which im not a fan of, change the one in the rear dif for the rear wheels, I always found this the most common to fail with dodge trucks. sorry didn't see your post that you have pulled the fuse. you can check sensors at the wheels with an ac voltmeter. but would need something to spin the wheel at a consistent low speed....its harder than it sounds and can be tough to detect
