Page 1 of 3 1 2 3
Cam recommenations updated 4/18 #2715686
11/14/19 12:43 PM
11/14/19 12:43 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
So my son has a 2011 charger 5.7 ex police car. I want to replace the lifters as I know they are most likely getting ready to fail I figure at that point may as well slide a cam in it. This car was well taken care of I know the cop that drove it from a small beach town near me it was well maintained has 90K miles on it. What is a decent cam that is still somewhat manageable to tune? I plan to delete the MDS and I know I will have to limit the VVT. The car has the 308 gear option as well. I would like to get this thing in the 12s it has run low 13s already.
Re: Cam recommenations [Re: biff426] #2715722
11/14/19 01:44 PM
11/14/19 01:44 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The stock 6.4 cam is great, I have swapped them into eagle 5.7s and they work great with no need to limit the VVT or even delete the MDS, you get the best of all worlds. They recently increased the price by double butt it is still a steal compared to aftermarket stuff. They work with stock springs and will still give a good increase in performance even before you tune it. With a tune they turn a 5.7 into an animal. Also don't listen to the MDS naysayers, I see lifters go bad frequently in 3/4 and 1 ton trucks that have no MDS system and I see bad ones in the non MDS lobes in the MDS engines, actually seems the MDS lifter lasts longer. I have torn apart far more of these engines than most of the youtubers and internet forum chatters who heard of a guy who knew a guy who had a bad MDS lifter.
Re: Cam recommenations [Re: HotRodDave] #2715790
11/14/19 04:35 PM
11/14/19 04:35 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
I have read mixed results with the 6.4 cam but it does seem like the easiest route to take. You have done it with the stock springs with no issues? I was planning to put a set of springs on it anyway and get it tuned. I am not concerned about the MDS lifters going bad so much as making more tuned power without the MDS. The people I have talked to all said they make more power without the MDS. This thing is not a driver where I am concerned about fuel mileage so ditching the MDS really doesn't hurt my feelings.
Re: Cam recommenations [Re: biff426] #2715823
11/14/19 06:15 PM
11/14/19 06:15 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I don't know what "mixed results" one could get from a 6.4 cam, they work great, better in fact then a lot of the similar sized aftermarket cams.
MDS will not affect power, it is not functioning when your engine is making more than about 30 HP. The MDS cam makes a tiny bit more peak HP and the NON MDS makes a tiny bit more elsewhere but that is the only difference.
Re: Cam recommenations [Re: biff426] #2715824
11/14/19 06:17 PM
11/14/19 06:17 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The stock 5.7 springs work fine, nearly identical spring pressure to a 6.4 spring, if you are concern about it buy the 6.4 springs, they drop right onto the head with no changes. 6.4 springs do cost about $200 where the 5.7 springs are $50.
Re: Cam recommenations [Re: HotRodDave] #2715937
11/14/19 09:50 PM
11/14/19 09:50 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
Thanks for the info I have been considering the 6.4 cam.
Re: Cam recommenations [Re: biff426] #2716583
11/16/19 11:26 PM
11/16/19 11:26 PM
Mesa , Az
Jambbii Offline
Jambbii  Offline
Mesa , Az
I did the cam swap in my wife's durango r/t per Dave's recommendation. I had the heads off and for 270 bucks for cam and springs I figured why not. It is a pretty good boost. In my opinion it needs a tune to take full advantage of it. Have about 6k miles on the swap. No issues so far!
70 Challenger
1960 Town Wagon P Pump 24v cummins project
06 Mega 3500 Drw 2wd
12 Durango R/T
18 Power Wagon
67 A100
Re: Cam recommenations [Re: Jambbii] #2716998
11/18/19 01:38 AM
11/18/19 01:38 AM
Are you guys degreeing these new cams or just aligning the dots?
HRD, how much lift and duration are they different?
Re: Cam recommenations [Re: Cab_Burge] #2717119
11/18/19 11:54 AM
11/18/19 11:54 AM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
So the Eagle and apache have the same installed height? I am thinking of just buying the 6.4 cam and springs and doing it. Appreciate all the info I have just done 6.1 and apache stuff never dug into an eagle head. Also I was going to put a new chain on it is it recommended to replace the sprockets and tensioners or is just a chain a acceptable. I really didn't want to get into a million dollar upgrade if I could help it I have 2 other gen 3 hemis in the mix right now.
Re: Cam recommenations [Re: Cab_Burge] #2717218
11/18/19 03:32 PM
11/18/19 03:32 PM
K
Kiddart Offline
Kiddart  Offline
K
Cab, I just lined up the dots per what a friend of mine told me to do. It runs really good. I have heard some have degreed them in and they did not run as good? If its good from the factory I figured it was good enough for me
Thank you
Kiddart
Re: Cam recommenations [Re: Kiddart] #2717378
11/19/19 01:31 AM
11/19/19 01:31 AM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
That's assuming replacement parts are the same as the parts they build them out of and in my experience, that's not always a safe assumption.
Kevin
Re: Cam recommenations [Re: Twostick] #2717541
11/19/19 02:16 PM
11/19/19 02:16 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The computer degrees it in real time. I am curious how people are "degreeing" these cams unless they lock down the phaser (dumb idea).
Re: Cam recommenations [Re: HotRodDave] #2717547
11/19/19 02:30 PM
11/19/19 02:30 PM
Still wishing...
Still wishing...
I didn't realize it was a VVT engine. So how do you verify that the camshaft and the ECM agree where the ICL etc is?
Kevin
Re: Cam recommenations [Re: Twostick] #2717599
11/19/19 04:25 PM
11/19/19 04:25 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I suppose you could lock a phaser down in the full advance position (it's static position butt it is spring loaded so it may change with real valve springs on it) and degree it that way, I have done it that way when I lock the cam permanently butt they seem to always be dead on unlike old school cams, it is a little more critical to have it exactly where it needs to be to prevent check engine lights from misfires and incorrect AF ratios from bad MAP readings or pre-ignition from too much cylinder pressure. Modern computers are much more sensitive to things being slightly out of wack. I sacrificed a spare cam phaser for such activities.
Re: Cam recommenations [Re: HotRodDave] #2726924
12/25/19 09:49 PM
12/25/19 09:49 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
HotRodDave, that spring info you gave is wrong. The 6.4 installed height is taller than the 5.7. A 6.4 spring CB is around 1.4. When installed at a 1.98 in an Eagle head you would be right on CB with a 6.4 cam.
Another thing, the 5.7s springs CB measurements are all over the place. From 1.30 to 1.37. However, the stock mopar springs have really stout pressures.
Re: Cam recommenations [Re: sixpackgut] #2728408
12/30/19 09:02 PM
12/30/19 09:02 PM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
Stock as deviled OEM heads , installed heights ....... Apache Intake 2.055 Exhaust 2.020
Eagle Intake 1.990 Exhaust 2.000..................When we did my 09 ram we removed the factory 0.081 spacer on a Eagle 5.7 and used a .030 shim to make give me some breathing room
Part # P5160074 is the Mopar performance spring for the Eagle heads that has a max lift of .625 designed to work with stock 5.7 keepers and locks, they are $280ish from Summit and 240ish from https://www.moparpartsgiant.com/parts/mopar-accessories_spring_valve-p5160074.html
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: Cam recommenations [Re: Ray408G3Hemi] #2728631
12/31/19 06:15 PM
12/31/19 06:15 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
I just went out to measure an eagle head. No shim I got 2.015. It came with .040 shim. I have a few .080 shims on the peg board so they must have made a change somewhere. Anyway
2.015-.570=1.445. So I really don't see how you can run a 6.4 spring safely at all
Also CB on the one spring out of this eagle head i just checked was 1.39
Re: Cam recommenations [Re: sixpackgut] #2728651
12/31/19 08:00 PM
12/31/19 08:00 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have 6.4 springs on my eagle heads with an SRT8 cam and it runs great, no coil bind and this is not the first one by any means. I could see daylight between every coil with the lifter bled down then shimmed solid with feeler gauges. Theoretical and actual are frequently different. I have 2 .040 shims in there, 3 and I could barely see light through a couple of the coils.
Re: Cam recommenations [Re: HotRodDave] #2728806
01/01/20 03:12 AM
01/01/20 03:12 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Your saying you have .080 shim with springs that came out of 6.4 heads? And cam lift is .571 correct?
Re: Cam recommenations [Re: sixpackgut] #2729091
01/01/20 06:03 PM
01/01/20 06:03 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The springs are what the local dodge dealer gave me when I asked for dodge challenger 6.4 valve springs and a stock 6.4 VVT MDS cam. I should see if I can find the part number.
Page 1 of 3 1 2 3
