Re: Sealants
[Re: johnfin]
#2716809
11/17/19 06:12 PM
11/17/19 06:12 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I don't really use any sealer on paper gaskets only around the seams or manifold edges. I use Superformance gaskets and make sure the surfaces are clean,dry,and flat then assemble with quality fasteners. When I need sealer I use Toyota black FPIG sealer for just about every thing oil or coolant related. On metal gaskets I use copper hytac spray or the brush-on stuff like you posted. I use liquid Teflon sealer on threaded applications because they come apart cleanly and there is very little mess with good leak-free results. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Sealants
[Re: johnfin]
#2716816
11/17/19 06:21 PM
11/17/19 06:21 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Only thing I use the "brown death" on is core plugs. RTV for everything else.
Re: Sealants
[Re: mopars4ever]
#2717229
11/18/19 04:05 PM
11/18/19 04:05 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Be careful with RTV... its the most mis-used and over-used chemical in all automotive applications. RTV should only be used as a filler of gap... example: intersecting corners (oil pan, intake); ok to use in place of front/rear intake rail gaskets, but again... be careful.. not too much.
NEVER apply RTV onto rubber gaskets... it then acts as a lubricant to allow the gasket to slip and move out-of-position upon getting squeezed under compression.
Also, for any bolts that enter into water ports, use a non-hardening thread sealer.
Best bet, read the gasket mfgr's instructions... I wrote the Fel-Pro FIT forms for gasket installations.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
Re: Sealants
[Re: second 70]
#2717550
11/19/19 02:34 PM
11/19/19 02:34 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
I use Gasket Cinch only on paper gaskets as well as on many other gasket that I need a adhesive on to hold it in place, follow the directions for success This X2 for coating paper gaskets. For anything else and on intake manifold I use Hylomar Blue.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
Re: Sealants
[Re: RoadRunner]
#2717554
11/19/19 02:44 PM
11/19/19 02:44 PM
Posts: 7,541 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
I use Gasket Cinch only on paper gaskets as well as on many other gasket that I need a adhesive on to hold it in place, follow the directions for success This X2 for coating paper gaskets. For anything else and on intake manifold I use Hylomar Blue. I have a bunch of tubes of Permatex products and select the right one for each job. I've used the non-hardening goop on paper and never had an issue. They come off easier. I avoid RTV - it adheres too strongly and I waste time scraping it off for a clean face. Cheers, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
