Sealants #2716789
11/17/19 04:42 PM
11/17/19 04:42 PM
gainsville, usa
johnfin Offline OP
johnfin  Offline OP
gainsville, usa
What type of sealants do you guys use on paper gaskets nowadays. I use to use these products back in the day. Seems like they are old school now
Re: Sealants [Re: johnfin] #2716809
11/17/19 06:12 PM
11/17/19 06:12 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I don't really use any sealer on paper gaskets only around the seams or manifold edges. I use Superformance gaskets and make sure the surfaces are clean,dry,and flat then assemble with quality fasteners. When I need sealer I use Toyota black FPIG sealer for just about every thing oil or coolant related. On metal gaskets I use copper hytac spray or the brush-on stuff like you posted. I use liquid Teflon sealer on threaded applications because they come apart cleanly and there is very little mess with good leak-free results.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Sealants [Re: johnfin] #2716813
11/17/19 06:18 PM
11/17/19 06:18 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
A whiff of the old permatex takes me back about 50 years, A real time tunnel smile
Currently I use / like the Permatex Ultra black beer
Re: Sealants [Re: johnfin] #2716816
11/17/19 06:21 PM
11/17/19 06:21 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Only thing I use the "brown death" on is core plugs. RTV for everything else.
Re: Sealants [Re: John_Kunkel] #2716819
11/17/19 06:39 PM
11/17/19 06:39 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Haven`t used that brown #2 stuff in years. I never really liked using it even back then. Mostly RTV for me nowadays. As said mostly dry gaskets unless I feel some sealer is necessary.
Re: Sealants [Re: mopars4ever] #2717229
11/18/19 04:05 PM
11/18/19 04:05 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Be careful with RTV... its the most mis-used and over-used chemical in all automotive applications. RTV should only be used as a filler of gap... example: intersecting corners (oil pan, intake); ok to use in place of front/rear intake rail gaskets, but again... be careful.. not too much.
NEVER apply RTV onto rubber gaskets... it then acts as a lubricant to allow the gasket to slip and move out-of-position upon getting squeezed under compression.
Also, for any bolts that enter into water ports, use a non-hardening thread sealer.
Best bet, read the gasket mfgr's instructions... I wrote the Fel-Pro FIT forms for gasket installations.
Re: Sealants [Re: johnfin] #2717319
11/18/19 09:31 PM
11/18/19 09:31 PM
I use Gasket Cinch only on paper gaskets as well as on many other gasket that I need a adhesive on to hold it in place, follow the directions for success thumbs scope
Re: Sealants [Re: Cab_Burge] #2717461
11/19/19 11:21 AM
11/19/19 11:21 AM
central il.
second 70 Offline
second 70  Offline
central il.
This
Re: Sealants [Re: second 70] #2717550
11/19/19 02:34 PM
11/19/19 02:34 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
This
X2 for coating paper gaskets.
For anything else and on intake manifold I use Hylomar Blue.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Sealants [Re: RoadRunner] #2717554
11/19/19 02:44 PM
11/19/19 02:44 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
This
up I have a bunch of tubes of Permatex products and select the right one for each job. I've used the non-hardening goop on paper and never had an issue. They come off easier. I avoid RTV - it adheres too strongly and I waste time scraping it off for a clean face. Cheers, - Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Sealants [Re: 67SATisfaction] #2717619
11/19/19 05:51 PM
11/19/19 05:51 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Form-A-Gasket hardening type is a must for freeze plugs. Old or not that stuff works.
I don't own any RTV that you find at the parts stores. When I need it I use GE window silicone from the Home Depot.
I have had good luck spending the time to find the sealants that are application specific - gear lube, antifreeze, etc.
Re: Sealants [Re: Neil] #2717641
11/19/19 07:37 PM
11/19/19 07:37 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
With very few exceptions I do not use sealants that are not called out as being the proper item for that joint.
I don't use sealant where a paper gasket goes. If I need to hold it in place I use thread.
I will use teflon tape on some bolts, such as the timing cover bolts on an LA. Because even though the factory didn't call that out anyone that has had one rust seize and break knows why.
I almost never use RTV, ever.
