MSD problem
#2714593
11/10/19 06:11 PM
11/10/19 06:11 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
I finally am going with a MSD setup. I have the 8546 distributor here and it and the cap (small cap) are hitting the valve cover. Cant even get dist to go into block. this is a Rb with tall aftermarket fabbed alum valve covers.
I hit the cover pretty good with a grinder but still a no-go.
What did you guys do to get around this ?
im thinking ill have to cut a chunk out of the cover , take that spot down a 1/4" and have someone weld the piece back on ??
Re: MSD problem
[Re: 493_DART]
#2714672
11/10/19 11:04 PM
11/10/19 11:04 PM
Posts: 422 montana
BANDIT
montana
What make of valve cover?
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
Re: MSD problem
[Re: 493_DART]
#2715498
11/13/19 07:39 PM
11/13/19 07:39 PM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
Mine clears the Mopar Performance finned valve covers. But didn't clear the hood..
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
