MSD problem #2714593
11/10/19 06:11 PM
11/10/19 06:11 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
I finally am going with a MSD setup. I have the 8546 distributor here and it and the cap (small cap) are hitting the valve cover. Cant even get dist to go into block. this is a Rb with tall aftermarket fabbed alum valve covers.
I hit the cover pretty good with a grinder but still a no-go.
What did you guys do to get around this ?
im thinking ill have to cut a chunk out of the cover , take that spot down a 1/4" and have someone weld the piece back on ??
Re: MSD problem [Re: 493_DART] #2714650
11/10/19 09:30 PM
11/10/19 09:30 PM
birdtracker Online boogie
birdtracker  Online Boogie
Off set distributor. Birdtracker
Re: MSD problem [Re: 493_DART] #2714672
11/10/19 11:04 PM
11/10/19 11:04 PM
montana
BANDIT Offline
BANDIT  Offline
montana
What make of valve cover?
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: MSD problem [Re: 493_DART] #2714699
11/11/19 02:35 AM
11/11/19 02:35 AM
I've had to grind down more than one cast aluminum covers, even the fabricated thin aluminum ones wit the thick flanges shruggy sawzall
Grind a little and check, repeat as needed to get it where you like it up
Re: MSD problem [Re: Cab_Burge] #2714707
11/11/19 06:40 AM
11/11/19 06:40 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Put a propane or map gas torch on the cover where it hits to soften the aluminum up some. Find something about the same dia, and wack till it clears. Or, cut and paste a section like a pro. I've clearanced several sets of aluminum covers that way, wedge, and hemi. Doesn't look bad believe it or not lol.
Re: MSD problem [Re: dthemi] #2715464
11/13/19 04:30 PM
11/13/19 04:30 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Yep--i did a lot of grinding to no avail. . Ive decided im going to cut out a small window , and have my buddy (a pro welder) weld in a thin cover piece on the inside . Should work--i dont care if the patch seen..but should be hidden by the cap anyway .
Re: MSD problem [Re: 493_DART] #2715498
11/13/19 07:39 PM
11/13/19 07:39 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
Mine clears the Mopar Performance finned valve covers. But didn't clear the hood..
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
