what rocker assembly for Eddy Hemi heads #2714817
11/11/19 02:34 PM
11/11/19 02:34 PM
Superfreak OP
Superfreak OP
Which rocker assemblies can be used on the Eddy Hemi Heads?
Thank You
Re: what rocker assembly for Eddy Hemi heads [Re: ] #2714845
11/11/19 03:30 PM
11/11/19 03:30 PM
lansing mi.
e85mope Offline
e85mope  Offline
lansing mi.
I used Norris rockers, but I don't think they are readily available any more. My suggestion would be stage V.
Re: what rocker assembly for Eddy Hemi heads [Re: e85mope] #2714855
11/11/19 04:16 PM
11/11/19 04:16 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
Any rocker basically. Stage V would be my only choice.
2011 Drag Pak Challenger
Re: what rocker assembly for Eddy Hemi heads [Re: rickseeman] #2714876
11/11/19 05:28 PM
11/11/19 05:28 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
T&D now makes a nice rocker system specifically for the Eddie Head - Also you have the Barton System
http://tdmach.com/product-category/rocker-arms/mopar/hemi/edelbrock-hemi/
Re: what rocker assembly for Eddy Hemi heads [Re: e85mope] #2714891
11/11/19 06:22 PM
11/11/19 06:22 PM
Washington
madscientist Offline
Washington
You can still get them. But Norris only does a run once a year or so. They may not have a set in stock, but they will eventually.
Re: what rocker assembly for Eddy Hemi heads [Re: ] #2714912
11/11/19 07:28 PM
11/11/19 07:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Harland-Sharp here for about 12+ years.......
Re: what rocker assembly for Eddy Hemi heads [Re: Thumperdart] #2714914
11/11/19 07:33 PM
11/11/19 07:33 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Harland Sharp doesn't make a hemi rocker system
Re: what rocker assembly for Eddy Hemi heads [Re: DoubleD] #2714916
11/11/19 07:38 PM
11/11/19 07:38 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Do those Edelbrock Hemi heads use a built in rocker stand system like Indys?
If so those rockers are awesome for Indy heads as well. And those T& D's are different than Bartons which uses a spray bar.
Re: what rocker assembly for Eddy Hemi heads [Re: Sammy] #2714942
11/11/19 08:42 PM
11/11/19 08:42 PM
Does Edlebrock make two different 426 hemi heads or just the one confused
I thought they made a Victor head casting as well as the one on display.
Re: what rocker assembly for Eddy Hemi heads [Re: Cab_Burge] #2714963
11/11/19 09:17 PM
11/11/19 09:17 PM
Stuttgart, Arkansas
Stuttgart, Arkansas
Yes, there are Edelbrock-casting Mopar heads. And then there are the Edelbrock Victor Jrs. Since they both take standard rockers, I guess it would work on either? I've used every rocker setup except those. So I don't know anything about them.
Re: what rocker assembly for Eddy Hemi heads [Re: Sammy] #2714980
11/11/19 09:56 PM
11/11/19 09:56 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Well neither of you are totally right, and I probably am not either because I do not see them in their catalogue, but they did build a set of G3 Hemi rockers
As far as G2 rockers, Stage V, Barton, Indy are among the best for the G2 Hemi. I have been running the Indy ones with no issues lately. Oiling can be an issue with anything but the Ray Barton / T&D ones....If I could afford a set, I would try them
Re: what rocker assembly for Eddy Hemi heads [Re: Dragula] #2714995
11/11/19 11:19 PM
11/11/19 11:19 PM
Superfreak OP
Superfreak OP
Thanks.
I am kind of between a rock and hard place with my parts. I shipped my Stage V's back to FHO and he is telling me that all the other castings he has are the same as I got. I have the option of waiting for new castings
but Tim doesn't think they will be any better. I said I would wait but then thinking about it I figured he could reimburse me as discussed but then he said he would reimburse me for the Ray Barton rocker assembly as well as they are specific for the heads.
So I figured ok, fine but then thinking again I realized my Stage V blower manifold was drilled for 6 bolt to match the heads. I figure the manifold is useless with the Eddy victor jr head so waiting to here back from Tim.
Re: what rocker assembly for Eddy Hemi heads [Re: Dragula] #2714999
11/11/19 11:26 PM
11/11/19 11:26 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
I’m going with Barton’s, I bought them though before T&D released Vic jr specific rockers
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: what rocker assembly for Eddy Hemi heads [Re: Sammy] #2715025
11/12/19 08:52 AM
11/12/19 08:52 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
No they do not have built in stands they are like a stock head - the T&D has a billet fixture that the shafts sit in - its pretty slick - I have the Barton system with push rod oiling - Best Machine has done a couple of HEMI's with the new T&D set-up look at their face book page
Re: what rocker assembly for Eddy Hemi heads [Re: Sammy] #2715113
11/12/19 12:54 PM
11/12/19 12:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My bad, missed the HEMI part...........
Re: what rocker assembly for Eddy Hemi heads [Re: Thumperdart] #2715260
11/12/19 09:26 PM
11/12/19 09:26 PM
Superfreak OP
Superfreak OP
So...I have to send back the manifold as well. Gd damit! now I have to start over again getting parts and a year wasted.
Re: what rocker assembly for Eddy Hemi heads [Re: ] #2715362
11/13/19 11:02 AM
11/13/19 11:02 AM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
Harland Sharp told me they could make any rocker arm I wanted...but I would pay for it. They did make a Gen 2 Hemi rocker at one time, but have not for many years.
Does anyone have a current contact number for Norris? I was under the impression that they closed up completely last summer.
