what rocker assembly for Eddy Hemi heads
#2714817
11/11/19 02:34 PM
11/11/19 02:34 PM
Superfreak
Superfreak
Which rocker assemblies can be used on the Eddy Hemi Heads?
Thank You
Re: what rocker assembly for Eddy Hemi heads
[Re: e85mope]
#2714891
11/11/19 06:22 PM
11/11/19 06:22 PM
Posts: 4,457 Washington
madscientist
Washington
I used Norris rockers, but I don't think they are readily available any more. My suggestion would be stage V. You can still get them. But Norris only does a run once a year or so. They may not have a set in stock, but they will eventually.
[Re: Thumperdart]
#2714914
11/11/19 07:33 PM
11/11/19 07:33 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Harland-Sharp here for about 12+ years....... Harland Sharp doesn't make a hemi rocker system
[Re: DoubleD]
#2714916
11/11/19 07:38 PM
11/11/19 07:38 PM
Sammy
Wind Gap,Pa.
Do those Edelbrock Hemi heads use a built in rocker stand system like Indys? If so those rockers are awesome for Indy heads as well. And those T& D's are different than Bartons which uses a spray bar.
[Re: Sammy]
#2714942
11/11/19 08:42 PM
11/11/19 08:42 PM
Posts: 43,118 Bend,OR USA
Cab_Burge
Does Edlebrock make two different 426 hemi heads or just the one I thought they made a Victor head casting as well as the one on display.
[Re: Cab_Burge]
#2714963
11/11/19 09:17 PM
11/11/19 09:17 PM
Posts: 2,631 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Yes, there are Edelbrock-casting Mopar heads. And then there are the Edelbrock Victor Jrs. Since they both take standard rockers, I guess it would work on either? I've used every rocker setup except those. So I don't know anything about them.
2011 Drag Pak Challenger
[Re: Sammy]
#2714980
11/11/19 09:56 PM
11/11/19 09:56 PM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
Harland-Sharp here for about 12+ years....... Harland Sharp doesn't make a hemi rocker system Well neither of you are totally right, and I probably am not either because I do not see them in their catalogue, but they did build a set of G3 Hemi rockers As far as G2 rockers, Stage V, Barton, Indy are among the best for the G2 Hemi. I have been running the Indy ones with no issues lately. Oiling can be an issue with anything but the Ray Barton / T&D ones....If I could afford a set, I would try them
[Re: Dragula]
#2714995
11/11/19 11:19 PM
11/11/19 11:19 PM
Superfreak
Superfreak
Thanks.
I am kind of between a rock and hard place with my parts. I shipped my Stage V's back to FHO and he is telling me that all the other castings he has are the same as I got. I have the option of waiting for new castings
but Tim doesn't think they will be any better. I said I would wait but then thinking about it I figured he could reimburse me as discussed but then he said he would reimburse me for the Ray Barton rocker assembly as well as they are specific for the heads.
So I figured ok, fine but then thinking again I realized my Stage V blower manifold was drilled for 6 bolt to match the heads. I figure the manifold is useless with the Eddy victor jr head so waiting to here back from Tim.
[Re: Dragula]
#2714999
11/11/19 11:26 PM
11/11/19 11:26 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
I’m going with Barton’s, I bought them though before T&D released Vic jr specific rockers
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: Sammy]
#2715025
11/12/19 08:52 AM
11/12/19 08:52 AM
Posts: 2,296 NE Ohio
DoubleD
NE Ohio
Do those Edelbrock Hemi heads use a built in rocker stand system like Indys? If so those rockers are awesome for Indy heads as well. And those T& D's are different than Bartons which uses a spray bar. No they do not have built in stands they are like a stock head - the T&D has a billet fixture that the shafts sit in - its pretty slick - I have the Barton system with push rod oiling - Best Machine has done a couple of HEMI's with the new T&D set-up look at their face book page
[Re: Sammy]
#2715113
11/12/19 12:54 PM
11/12/19 12:54 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
My bad, missed the HEMI part...........
[Re: Thumperdart]
#2715260
11/12/19 09:26 PM
11/12/19 09:26 PM
Superfreak
Superfreak
So...I have to send back the manifold as well. Gd damit! now I have to start over again getting parts and a year wasted.
