1969 Starter #2713983
11/08/19 01:56 PM
11/08/19 01:56 PM
Kentucky USA
RR6BBL1969 Offline OP
Kentucky USA
I have a starter with a cast number : 2095219. There is a 9 above the cast number. Is it correct for a post Jan. 1969 drive train?
Re: 1969 Starter [Re: RR6BBL1969] #2714184
11/09/19 11:09 AM
11/09/19 11:09 AM
VA
dragon slayer Offline
VA
This is for an auto not 4 speed correct? The direct drive starter for a 4 speed was casting number 2642443 for 66 and 2642928 67 to 69. Can't help you on the auto version.
Re: 1969 Starter [Re: dragon slayer] #2714539
11/10/19 02:15 PM
11/10/19 02:15 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
Can you post some pictures?
Re: 1969 Starter [Re: Paul Jacobs] #2714573
11/10/19 04:52 PM
11/10/19 04:52 PM
Kentucky USA
Kentucky USA
Re: 1969 Starter [Re: RR6BBL1969] #2714575
11/10/19 04:55 PM
11/10/19 04:55 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The snout & the rear steel section will both have date codes.
You can clean it up to look for them & then post closeups.
Re: 1969 Starter [Re: dragon slayer] #2714576
11/10/19 04:56 PM
11/10/19 04:56 PM
Kentucky USA
Kentucky USA
Don't know if it came off a standard or automatic, just had it lying on the shelf .
