727 Trasmission Shifts Late
#567305
12/30/09 10:12 PM
12/30/09 10:12 PM
Posts: 352 Arizona
69rrgrabber
Arizona
I just got this 69 Charger R/T running after 15 years! The problem I have is that the 727 transmission shifts late from 1st to 2nd and especially 2nd to 3rd. I have to get up to 40, 45 mph and then let off the gas to get it to shift to 3rd. The tranny is full of fluid in nutral and has a new filter. This is my first Mopar with an auto and I really am clueless on how to adjust the shift points. Is the arm that goes to the carb throttle bracket the only adjust point? Thanks Carl
"It takes a Mopar to catch a Mopar!"
1969 Charger R/T 440
1969 Road Runner 383
1970 Cuda 440
Re: 727 Trasmission Shifts Late
[Re: Greentween]
#567307
12/30/09 10:37 PM
12/30/09 10:37 PM
Posts: 352 Arizona
69rrgrabber
Arizona
Ok, so I should shorten it and have a space between the pin on the throttle linkage and the back of the oval opening on the kick down?
Forgot to mention that its a Eddy 750 carb.
Carl
1970 Cuda 440
[Re: 69rrgrabber]
#567308
12/30/09 11:06 PM
12/30/09 11:06 PM
RapidRobert
shorten it by turning the turnbuckle w the elongated slot CW which will increase the "space" but your return spring will pull the slot forward taking up the space so the carb pin will still be at the rear end of the elongated slot (as before)but the end result that will help you is the linkage at the trans will not be pushed as far back at any given throttle which is what you want to lower the shift points. EDIT check the linkage further rearward/down & if there's a threaded adjustment shorten it there.
[Re: 69rrgrabber]
#567309
12/30/09 11:35 PM
12/30/09 11:35 PM
Posts: 25,821 Rio Linda, CA
John_Kunkel
Rio Linda, CA
To make the linkage work correctly on the Edelbrock you need their Mopar throttle lever extension (part number 1481)
[Re: MoparforLife]
#567311
12/31/09 11:52 AM
12/31/09 11:52 AM
Posts: 352 Arizona
69rrgrabber
Arizona
You're right, the spring is missing! I'll get one and install it. Thanks Carl
1970 Cuda 440
[Re: fc7_plumcrazy]
#2714405
11/10/19 12:15 AM
11/10/19 12:15 AM
Posts: 7,539 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Hope someone can help you out Carsten, but thanks for reviving this thread -
I used the info to tweak the less-than-perfectly shifting 727's on both my Satellites and they are 90% better.. just a little more tweaking with a better return spring and the 8003 extension from Summit... Cheers, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: fc7_plumcrazy]
#2714584
11/10/19 05:20 PM
11/10/19 05:20 PM
John_Kunkel
Rio Linda, CA
Hi,
the old pics are gone. Does anyone have pictures to get an idear?
Carsten The parts labeled 1 and 12 are where the adjustment is made for early/late shifts.
