727 Trasmission Shifts Late #567305
12/30/09 10:12 PM
12/30/09 10:12 PM
Arizona
69rrgrabber Offline OP
Arizona
I just got this 69 Charger R/T running after 15 years! The problem I have is that the 727 transmission shifts late from 1st to 2nd and especially 2nd to 3rd. I have to get up to 40, 45 mph and then let off the gas to get it to shift to 3rd. The tranny is full of fluid in nutral and has a new filter.
This is my first Mopar with an auto and I really am clueless on how to adjust the shift points. Is the arm that goes to the carb throttle bracket the only adjust point?
Carl
"It takes a Mopar to catch a Mopar!" 1969 Charger R/T 440 1969 Road Runner 383 1970 Cuda 440
Re: 727 Trasmission Shifts Late [Re: 69rrgrabber] #567306
12/30/09 10:25 PM
12/30/09 10:25 PM
ILL
Greentween Offline
Greentween  Offline
ILL
Yes you are correct, adjust the rod attached on the throttle. Turn it so its not pushing it back as far.
Re: 727 Trasmission Shifts Late [Re: Greentween] #567307
12/30/09 10:37 PM
12/30/09 10:37 PM
Arizona
Arizona
Ok, so I should shorten it and have a space between the pin on the throttle linkage and the back of the oval opening on the kick down?
Forgot to mention that its a Eddy 750 carb.
Carl
Re: 727 Trasmission Shifts Late [Re: 69rrgrabber] #567308
12/30/09 11:06 PM
12/30/09 11:06 PM
Happy Birthday RapidRobert  Offline
shorten it by turning the turnbuckle w the elongated slot CW which will increase the "space" but your return spring will pull the slot forward taking up the space so the carb pin will still be at the rear end of the elongated slot (as before)but the end result that will help you is the linkage at the trans will not be pushed as far back at any given throttle which is what you want to lower the shift points. EDIT check the linkage further rearward/down & if there's a threaded adjustment shorten it there.
Re: 727 Trasmission Shifts Late [Re: 69rrgrabber] #567309
12/30/09 11:35 PM
12/30/09 11:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
To make the linkage work correctly on the Edelbrock you need their Mopar throttle lever extension (part number 1481)
Re: 727 Trasmission Shifts Late [Re: 69rrgrabber] #567310
12/31/09 07:28 AM
12/31/09 07:28 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Carl
Sounds to me like you don't have the small spring attached from the carb throttle pin to the belcrank that hold teh rear of the KD linkage slot up tight to the throttle pin at all times to keep constant progressive contact throughout the complete travel of the throttle. This is what controls the shift points of the transmission. Number 13 in picture.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: 727 Trasmission Shifts Late [Re: MoparforLife] #567311
12/31/09 11:52 AM
12/31/09 11:52 AM
Arizona
Arizona
You're right, the spring is missing! I'll get one and install it.
Carl
Re: 727 Trasmission Shifts Late [Re: 69rrgrabber] #567312
01/02/10 07:09 AM
01/02/10 07:09 AM
Arizona
Arizona
I shortened the rod several times and now it shifts great. Thanks a bunch!
Re: 727 Trasmission Shifts Late [Re: 69rrgrabber] #2708448
10/20/19 08:03 AM
10/20/19 08:03 AM
Germany
fc7_plumcrazy Offline
Germany
Hi,
the old pics are gone.
Does anyone have pictures to get an idear?
Carsten
Re: 727 Trasmission Shifts Late [Re: fc7_plumcrazy] #2714405
11/10/19 12:15 AM
11/10/19 12:15 AM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Hope someone can help you out Carsten, but thanks for reviving this thread -
I used the info to tweak the less-than-perfectly shifting 727's on both my Satellites and they are 90% better.. just a little more tweaking with a better return spring and the 8003 extension from Summit...
Cheers,
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: 727 Trasmission Shifts Late [Re: fc7_plumcrazy] #2714584
11/10/19 05:20 PM
11/10/19 05:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted by fc7_plumcrazy
Hi,
Carsten
The parts labeled 1 and 12 are where the adjustment is made for early/late shifts.
