Re: Hemi project almost done
[Re: Hemi ragtop]
#2714270
11/09/19 03:05 PM
11/09/19 03:05 PM
Posts: 31,060 Oregon
AndyF
4.5 inch stroke? Wow, it should make some torque. Not sure about the HP but it will definitely make some torque. Were you able to fit an internal oil pickup tube around the 4.50 inch stroke? I see the external line so I'm guessing you removed the internal pickup and are external only?
[Re: AndyF]
#2714309
11/09/19 06:05 PM
11/09/19 06:05 PM
Posts: 984 Tennessee
Hemi ragtop
Tennessee
4.5 inch stroke? Wow, it should make some torque. Not sure about the HP but it will definitely make some torque. Were you able to fit an internal oil pickup tube around the 4.50 inch stroke? I see the external line so I'm guessing you removed the internal pickup and are external only? Yes I have a external swinging pickup with baffles.
[Re: Hemi ragtop]
#2722256
12/07/19 11:18 AM
12/07/19 11:18 AM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
Man that car would be a blast to cruise. Nice numbers, should be real hard on tires lol.
68 Barracuda Formula S 340
[Re: Hemi ragtop]
#2722261
12/07/19 11:24 AM
12/07/19 11:24 AM
Hemi ragtop
Tennessee
Perhaps I shouldn’t post details of this engine on a “racing” forum, but I enjoy reading the technical info posted here and thought you might be interested in a “slightly different” build. This engine was built for a real “street” car that weighs 4,175lb, has a 727 with the tightest possible 11” converter, 3.54 gears and a Gear Vendor overdrive. So, torque, high idle vacuum for the power disk brakes, low speed drivability, low maintenance and the ability to buy gas anywhere I happened to find myself, were the priorities. All the clearances were set on the tight side. Diamond coated 4032 allow pistons were chosen for the tight .003-.0035 piston to wall clearance were used. All the bearings are coated, a Napier second ring was used for oil control. The engine will run full. Synthetic low viscosity oil and pump gas.
[Re: Hemi ragtop]
#2722265
12/07/19 11:27 AM
12/07/19 11:27 AM
Bad340fish
Tulsa OK
Unlawful's Race & Engine tech, I think your threads fit in here just fine.
[Re: Hemi ragtop]
#2722271
12/07/19 12:04 PM
12/07/19 12:04 PM
Posts: 452 Monrovia, So-Cal, USA
racerhog
Very nice Job.... Hope it last a long life and gives you good service.... Keep us posted on the driving part !!!! Mopar On !!!
Bob(Cowboy)Hogan Monrovia So-Cal
