1969 Charger Disk Brakes #2713635
11/07/19 11:42 AM
11/07/19 11:42 AM
WV
JohnH Offline OP
JohnH  Offline OP
WV
I want to install front disk brakes on my 69 B Body... I have power brakes, What can I get thats not a major operation to install without changing booster... I don't mind changing spindles and what ever I need to replace at the wheel.. Thanks
Re: 1969 Charger Disk Brakes [Re: JohnH] #2713643
11/07/19 12:02 PM
11/07/19 12:02 PM
AndyF Offline
AndyF  Offline
Doctor Diff has everything you need.
Re: 1969 Charger Disk Brakes [Re: AndyF] #2713701
11/07/19 02:20 PM
11/07/19 02:20 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
X2 . . . . . Dr. Diff ! Cass is very knowledgeable and helpful . . .
Re: 1969 Charger Disk Brakes [Re: a12rag] #2713709
11/07/19 02:48 PM
11/07/19 02:48 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Your current master cylinder is going to have equal sized reservoirs for the front and rear brakes. While technically it will work, a disc brake master cylinder will have a larger reservoir for the disc brakes. The calipers displace more brake fluid as the pads wear then do the wheel cylinders. Replace your master cylinder. twocents
Re: 1969 Charger Disk Brakes [Re: burdar] #2714164
11/09/19 09:38 AM
11/09/19 09:38 AM
VA
dragon slayer Offline
VA
Doing a search on this subject will really help you determine what you want to do. OEM, After market, etc... Do you need to keep this like an original 69 set up, or anything that works is fine. What cost? All that will factor in to what you want.
Re: 1969 Charger Disk Brakes [Re: JohnH] #2714191
11/09/19 11:29 AM
11/09/19 11:29 AM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
Do yourself a favor and just order from Dr. Diff and be done with it. Great stuff and the best customer service that you will find. I converted my power Bendix disc system and it works great, I left the booster alone and ordered one of his master cylinders as well.
Re: 1969 Charger Disk Brakes [Re: Belvedere1] #2714217
11/09/19 12:53 PM
11/09/19 12:53 PM
moparx Offline
moparx  Offline
did you use the original single diaphragm drum brake booster ?
if so, how does it stop for you ?
beer
Re: 1969 Charger Disk Brakes [Re: moparx] #2714263
11/09/19 02:18 PM
11/09/19 02:18 PM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
My car was an original power disc so I just used the same booster from the old 4 piston set up. It stops great now with the A body brake conversion.
Re: 1969 Charger Disk Brakes [Re: Belvedere1] #2714504
11/10/19 12:29 PM
11/10/19 12:29 PM
moparx Offline
moparx  Offline
thanks.
i believe, since your car was an original 4 piston disc car, your booster would have been a dual diaphragm unit.
beer
