4.25 stroke small block. Experience? #2712232
11/02/19 09:28 PM
11/02/19 09:28 PM
Between a rock & a hard place
cudadoug Offline OP
cudadoug  Offline OP
Anyone have the good, bad or ugly with a 4.25” crank in a small block??
Seems like ALOT of crank in a small space.
Any excessive side loading anyone have an opinion on?
Bloomer, you out there somewhere???
Thanks in advance.
Re: 4.25 stroke small block. Experience? [Re: cudadoug] #2712275
11/02/19 11:03 PM
11/02/19 11:03 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Moparbilly’s IMM built small block mill was a 4.25 piece. Couple of drag weeks, nos assisted quarter passes, drove it around metro Phoenix... pretty stout well thought out combo.
*my bad.... I believe that was a 4.125 stroke in moparbilly’s
Re: 4.25 stroke small block. Experience? [Re: cudadoug] #2712283
11/02/19 11:38 PM
11/02/19 11:38 PM
AndyF Offline
AndyF  Offline
I did a 427 inch SB once using a 4.125 crank with small journal chevy rods. Things were very close. The windage tray had to be modified, we tried several different oil pickup tubes before finding one that worked, etc. Hughes might still sell their stroker kit with the 4.180 stroke and Honda journals. That combo might clear things a little better. I'm not so sure I'd try the 4.250 combo unless I had a lot of time and patience.
Re: 4.25 stroke small block. Experience? [Re: AndyF] #2712284
11/02/19 11:41 PM
11/02/19 11:41 PM
gregsdart Offline
gregsdart  Offline
Was it Ron Silva that built a 501 cube smallblock, posted here? Google Silvaliant
Re: 4.25 stroke small block. Experience? [Re: gregsdart] #2712450
11/03/19 03:14 PM
11/03/19 03:14 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I got 2 4.25"/2.0" cranks, a 340 & 360. the 340 is supposed to be in a deep skirt A8 alum dry sump block. As we all know, both Rome and A8's aren't built in a day. bawling
Re: 4.25 stroke small block. Experience? [Re: jcc] #2712502
11/03/19 06:21 PM
11/03/19 06:21 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I use a Rod Bloomer 4.250 crank in my old x block. Its worked well. I dont use a standard style pick up.Thats where a big problem is. I have a Kevco pan with arear pick up.It cleared everything with minimal work. On my Molnar 4.125 crank it helped to cut the front and rear counter weight about .300. Using comp star rods and JE pistons it balanced very easy. The 4.250 x 4.125 x block has been 5.66 at about 121. I dont spin it very high, I shiift it about 65-6600
If this web site werent so difficult some older members might stop in more often. I havent been here in quite some time.
Re: 4.25 stroke small block. Experience? [Re: DavidDean] #2712666
11/04/19 12:57 PM
11/04/19 12:57 PM
cudadoug Offline OP
cudadoug  Offline OP
Thanks all! I have access to a 4.25" crank motor, in an R3 block (with the Bloomer kit) and by biggest concern was excess side loading of the cylinder walls. So I text Bloomer Saturday and he responds. Not only did he respond, but he was on a break during a bow hunting trip. Now, THAT is service after the sale!
Re: 4.25 stroke small block. Experience? [Re: cudadoug] #2712683
11/04/19 01:44 PM
11/04/19 01:44 PM
Northern Bavaria / Germany
MichaelF Offline
MichaelF  Offline
you mind sharing what he had to say? interested in this stuff also....Thanks!
Michael
Re: 4.25 stroke small block. Experience? [Re: J_BODY] #2712711
11/04/19 03:20 PM
11/04/19 03:20 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
You're right Billy's was a 4.125 stroke. I still have a copy of the receipt with the specs that Billy posted on here once. I believe Streetwise did a 4.25 stroke on the relatively cheap though.
Re: 4.25 stroke small block. Experience? [Re: MichaelF] #2712982
11/05/19 12:23 PM
11/05/19 12:23 PM
cudadoug Offline OP
cudadoug  Offline OP
Michael
Just that in a nutshell, the excess side loading deal is all talk. His piston called for a .003 piston to wall clearance to minimize piston rock to further help the situation. He claims many 4.25" crank combos in service with thousands of runs/miles, with no issues that he has been aware of.
I must say again, Bloomer was great about my questions. We left our conversation with him wishing me luck if I bought this motor and if I had any more questions to reach out to him. Class guy! .
Re: 4.25 stroke small block. Experience? [Re: DavidDean] #2712985
11/05/19 12:26 PM
11/05/19 12:26 PM
cudadoug Offline OP
cudadoug  Offline OP
has been 5.66 at about 121. shocked
Re: 4.25 stroke small block. Experience? [Re: cudadoug] #2713018
11/05/19 02:21 PM
11/05/19 02:21 PM
MichaelF Offline
MichaelF  Offline
Michael
Thanks a lot!
Michael
