Brewers Perf or Passon Perf #2712962
11/05/19 11:40 AM
11/05/19 11:40 AM
South San Francisco, Ca
70sixpkrt Offline OP
I'm going to replace my clutch next month and at the same time my buddy is going to rebuild my trans. I have a popping out of first gear issue. Just wondering on who is better for rebuild kits, syncros, possibly first gear, etc... I have ordered stuff from Passon Perf about 18 years ago but just wondering now a days. Good bad on either place. Thanks.
single choice
Votes accepted starting: 11/05/19 11:40 AM
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Brewers Perf or Passon Perf [Re: 70sixpkrt] #2712965
11/05/19 11:51 AM
11/05/19 11:51 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The answer is "Yes" Either vendor will do a great job, there is no bad choice
Re: Brewers Perf or Passon Perf [Re: ScottSmith_Harms] #2712969
11/05/19 11:56 AM
11/05/19 11:56 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Scott is probably right but I have always dealt with Brewers and had nothing but 110% positive experiences twocents
Re: Brewers Perf or Passon Perf [Re: TJP] #2712981
11/05/19 12:21 PM
11/05/19 12:21 PM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
Agree on both being a yes.
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: Brewers Perf or Passon Perf [Re: MoparJunkie] #2712984
11/05/19 12:26 PM
11/05/19 12:26 PM
Ohio
lockjaw-express Offline
Ohio
Wayne and Danny are the Best out there for Rebuilding and Restoring Mopar Manual Transmissions...Passon has great parts, and Brewers is Very Dependable and spot on when restoring a Mopar Transmission!
Re: Brewers Perf or Passon Perf [Re: lockjaw-express] #2713107
11/05/19 06:42 PM
11/05/19 06:42 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
I have dealt with Jamie Passion several times. Great guy, very knowledgeable. Have never heard anything bad about either. It's great to have more than one excellent option.
1981 Dodge D150 360 auto
Re: Brewers Perf or Passon Perf [Re: ScottSmith_Harms] #2713133
11/05/19 08:09 PM
11/05/19 08:09 PM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
I agree with Scott!
Re: Brewers Perf or Passon Perf [Re: basketcase] #2713134
11/05/19 08:10 PM
11/05/19 08:10 PM
Slidell, LA
Plum440 Offline
Plum440  Offline
Slidell, LA
I'm a happy Brewer's customer. No bad experiences and VERY good people. thumbs
70 Challenger, 440, 4-speed, pLuM cRaZy
71 VW Super Beetle Convertible, Lemon Yellow
A couple of Jeeps…
Re: Brewers Perf or Passon Perf [Re: Plum440] #2713321
11/06/19 12:31 PM
11/06/19 12:31 PM
Thanks everyone.
4-speed
3:54 Dana
Re: Brewers Perf or Passon Perf [Re: 70sixpkrt] #2713364
11/06/19 01:52 PM
11/06/19 01:52 PM
Are you sure that your shifter is adjusted correctly in all gears?
If not do that first before fixing something that may not be broken work scope
I've seen this on more than one Mopar, A,B and E bodies shruggy
The shift rods and shift levers get worn and won't let the tranny engage the gears properly and completely scope
To check it have someone shift it into each gear one at a time and then remove the shift rod from the tranny shift lever and see if you can move it forward more into gear, make sure and watch the lever when you remove the rods to see if it moves on its own scope
Good luck, let us know what you find thumbs
