GTX stuck in 2nd gear #2711374
10/30/19 07:17 PM
10/30/19 07:17 PM
milton PA. USA
W
waynecawley69 Offline OP
W
milton PA. USA
Took the GTX out for a ride the other day. Its a 4spd & it has new linkage, shifter & syncros. Ive drove it many times before. I went to down shift into 2nd gear to turn onto another road & got stuck in 2nd. The shifter seams to be in the neutral position. There is a noise coming from the bell housing area. Not sure what that is. Havent had the chance plus no electric in the garage right now to take a look at it. Any one with an idea ?
Re: GTX stuck in 2nd gear [Re: waynecawley69] #2711402
10/30/19 08:06 PM
10/30/19 08:06 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
With a bit of luck, maybe one of the shifter arms, or mount came loose. Or maybe a linkage rod fell out. Have to get under their and see if it's an external problem. Keep us posted beer
Re: GTX stuck in 2nd gear [Re: TJP] #2711432
10/30/19 09:53 PM
10/30/19 09:53 PM
milton PA. USA
W
W
milton PA. USA
Im hoping so I will thanks
Re: GTX stuck in 2nd gear [Re: waynecawley69] #2711484
10/31/19 04:42 AM
10/31/19 04:42 AM
Slidell, LA
Plum440 Offline
Plum440  Offline
Slidell, LA
Happened to me. It was a loose shift ear on the gear box.
70 Challenger, 440, 4-speed, pLuM cRaZy
71 VW Super Beetle Convertible, Lemon Yellow
A couple of Jeeps…
Re: GTX stuck in 2nd gear [Re: Plum440] #2712286
11/02/19 11:47 PM
11/02/19 11:47 PM
USA
Rollin Hand Offline
Rollin Hand  Offline
USA
Why did you change profiles Cawley? I see your car for sale by 69BBCUDA4SPD in the for sale section. Are you trying to hide something? Cawley or XMANJR or whatever you call yourself, your still a scammer turd.
Re: GTX stuck in 2nd gear [Re: Rollin Hand] #2713089
11/05/19 05:39 PM
11/05/19 05:39 PM
Minnesota
peabodyracing Offline
Minnesota
That happened to me last year with a recently assembled car. I'd driven it up and down the road without incident and the first time I got on it hard, it stuck in second gear. I too had a new noise coming from the transmission.
Put the car back on the hoist and disconnected the shifter linkage and putting a wrench on the shifter arm turned it back into neutral position. Took a bit of effort to turn it back, but not alarmingly so. Turned out the shifter stop wasn't quite in far enough. Turned that in about a turn and no more problems.
Lead, follow or get the hell out of the way
Re: GTX stuck in 2nd gear [Re: peabodyracing] #2714646
11/10/19 09:12 PM
11/10/19 09:12 PM
USA
Rollin Hand Offline
Rollin Hand  Offline
USA
I see your selling this car on FORBBODIESONLY with a reduced price of 40k with a trans issue. Tell us more XMANJR.
