ST-437 Swedge Cutter #2702292
09/30/19 03:18 PM
09/30/19 03:18 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
I've been looking for a wheel stud swedge cutter for 7/16" studs. The Goodson ST-437 would have worked but they no longer offer it. For $1060 they'll make one for me but I think I'll pass on that idea. Does anyone know of another supplier? I've looked for a couple days and can't find anything comparable. Thanks!
Re: ST-437 Swedge Cutter [Re: 6PakBee] #2702303
09/30/19 03:41 PM
09/30/19 03:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A 9/16" hole saw with the arbor removed?
Re: ST-437 Swedge Cutter [Re: 6PakBee] #2702309
09/30/19 03:54 PM
09/30/19 03:54 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I promised to make some 1/2 inch cutters for some folks and would not be a problem to make them 7/16. I could make one for you next week.
Mine are great if you only use them sporadically. I make them from hardened drill rod. I have not had the incentive to make a carbide tipped cutter.
Re: ST-437 Swedge Cutter [Re: John_Kunkel] #2702310
09/30/19 04:00 PM
09/30/19 04:00 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Please tell us you are not a machinist?
Re: ST-437 Swedge Cutter [Re: markz528] #2702312
09/30/19 04:07 PM
09/30/19 04:07 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Marks528
How much do you charge for these?
Re: ST-437 Swedge Cutter [Re: Ply72rr] #2702322
09/30/19 05:24 PM
09/30/19 05:24 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Marks528
I make them for fun not profit. If you are interested send me a PM.
Re: ST-437 Swedge Cutter [Re: Alaskan_TA] #2702336
09/30/19 06:16 PM
09/30/19 06:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Never claimed to be but the concept isn't as foreign as you might think.
http://www.binderplanet.com/forums/index.php?threads/poor-mans-swage-cutter.130261/
Re: ST-437 Swedge Cutter [Re: markz528] #2702337
09/30/19 06:17 PM
09/30/19 06:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Got a pic?
Re: ST-437 Swedge Cutter [Re: John_Kunkel] #2702343
09/30/19 06:40 PM
09/30/19 06:40 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Got a pic?
Not home till Wednesday - will post one then.
Re: ST-437 Swedge Cutter [Re: markz528] #2702594
10/01/19 12:30 PM
10/01/19 12:30 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
Got a pic?
Super! I'll wait for the picture but I am interested.
Re: ST-437 Swedge Cutter [Re: 6PakBee] #2702797
10/01/19 11:39 PM
10/01/19 11:39 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
They would look something like this but with a reduced 1/2" shank to fit in a 1/2" chuck. I would make sure they fit correctly over a 1/2" or 7/16" stud. I have used these before and they worked very well.
Re: ST-437 Swedge Cutter [Re: markz528] #2702911
10/02/19 09:22 AM
10/02/19 09:22 AM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
That is very gracious offering to make these for free. up There is a bit of work and set up time involved there with the heat treatment and the alloy material isn't free either. I do little do dads like this often. I think I'd need to get $30-$40 for one of these unless I know you.
Re: ST-437 Swedge Cutter [Re: gzig5] #2711987
11/01/19 10:00 PM
11/01/19 10:00 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Well I'm a Dumb-$^#! My prototype 1/2" cutter is a left hand cutter! LOL! But the good news is it cuts great!
So it will take a bit to correct my drawing and programs............
Re: ST-437 Swedge Cutter [Re: markz528] #2712052
11/02/19 10:45 AM
11/02/19 10:45 AM
moparx Offline
moparx  Offline
how many times over the years have i designed, fabbed, built stuff, only to have it come out REVERSED from what it should have been. laugh2
i'm not only a member of the DUMAZZ club, i think i INVENTED it. whistling
i know your feelings intimately !
looks like it does work good though. up
beer
Re: ST-437 Swedge Cutter [Re: moparx] #2712281
11/02/19 11:13 PM
11/02/19 11:13 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I recovered pretty good. Roughed out (7) 7/16" and (9) 1/2" cutters today. Need to cut the shanks, harden and grind before they are done.
Re: ST-437 Swedge Cutter [Re: markz528] #2712418
11/03/19 01:39 PM
11/03/19 01:39 PM
moparx Offline
moparx  Offline
GREAT recovery indeed ! they look good !
beer
Re: ST-437 Swedge Cutter [Re: 6PakBee] #2913739
04/23/21 02:47 AM
04/23/21 02:47 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
I'm using the Goodson ST-437 that I was lucky enough to buy 6 months before the OP posted. Maybe the last one?
Can someone who has cut the swages off their front brake drum lug studs please tell me if I have gone deep enough to press out the studs? I went just deep enough for the tool to fully clean up both the lug studs and the drum. But I'm wondering if maybe the stud is swaged or mushroomed deeper than the top surface of the drum? How much below the top surface of the drum should I go?
Should I replace the drum after using this tool?
Before I bought the tool and not knowing the studs were swaged, I pressed on a stud with my 12-ton press against a socket around the stud head and it warped the drum. I'm trying to avoid repeating that fiasco if the drum is salvageable after de-swaging.
Re: ST-437 Swedge Cutter [Re: kentj340] #2913740
04/23/21 02:50 AM
04/23/21 02:50 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Close up of the tool with carbide cutters.
Re: ST-437 Swedge Cutter [Re: kentj340] #2913857
04/23/21 11:57 AM
04/23/21 11:57 AM
moparx Offline
moparx  Offline
i think you may be good where you are at.
one way to find out. lightly tap on the broken stud, "lightly" being a subjective term, just not 12 tons of force. if it moves, you are good to go.
there is some press fit on the drum bore to hub od, but i don't know, or remember, how much that is.
beer
Re: ST-437 Swedge Cutter [Re: John_Kunkel] #2913885
04/23/21 12:43 PM
04/23/21 12:43 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Pretty sure that guy kept the arbor and removed the pilot drill.
