Re: Tunnel ram linkage
[Re: wyldebill]
#2711328
10/30/19 05:27 PM
10/30/19 05:27 PM
Posts: 4,457 Washington
madscientist
Washington
What linkage are you running on a Hogan sheet metal for a bb tunnel ram? Sideways dominates. Thanks Good Vibrations Motorsports has good linkage.
[Re: wyldebill]
#2711370
10/30/19 07:09 PM
10/30/19 07:09 PM
Posts: 4,206 New York
polyspheric
New York
Unless you have a non-alignment problem, a quality clevis is much less $$$ than Heim joint.
Boffin Emeritus
[Re: Cab_Burge]
#2711414
10/30/19 09:04 PM
10/30/19 09:04 PM
madscientist
Washington
I've used the Enderle kit that Summits sells as well as several other brands that I can't rermember the names of them now For some reason I couldn't think of Enderle. That's the same kit that Good Vibrations sells. IIRC I bought from GV because they were cheaper that summit.
[Re: Sammy]
#2711454
10/30/19 11:16 PM
10/30/19 11:16 PM
madscientist
Washington
Theres a much better one out there now. Uses a bellcrank style. But twice the price. Do,you have a link to that linkage? I'd like to see it. TIA
