Tunnel ram linkage #2711287
10/30/19 03:18 PM
10/30/19 03:18 PM
Midland,Tx
wyldebill Offline OP
Midland,Tx
What linkage are you running on a Hogan sheet metal for a bb tunnel ram?
Sideways dominates. Thanks
Re: Tunnel ram linkage [Re: wyldebill] #2711328
10/30/19 05:27 PM
10/30/19 05:27 PM
Washington
madscientist Offline
Washington
Good Vibrations Motorsports has good linkage.
Re: Tunnel ram linkage [Re: wyldebill] #2711370
10/30/19 07:09 PM
10/30/19 07:09 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Unless you have a non-alignment problem, a quality clevis is much less $$$ than Heim joint.
Boffin Emeritus
Re: Tunnel ram linkage [Re: wyldebill] #2711401
10/30/19 08:03 PM
10/30/19 08:03 PM
I've used the Enderle kit that Summits sells as well as several other brands that I can't rermember the names of them now blush
Re: Tunnel ram linkage [Re: Cab_Burge] #2711414
10/30/19 09:04 PM
10/30/19 09:04 PM
Washington
Washington
For some reason I couldn't think of Enderle. That's the same kit that Good Vibrations sells. IIRC I bought from GV because they were cheaper that summit.
Re: Tunnel ram linkage [Re: madscientist] #2711419
10/30/19 09:24 PM
10/30/19 09:24 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Theres a much better one out there now.
Uses a bellcrank style. But twice the price.
Re: Tunnel ram linkage [Re: Sammy] #2711429
10/30/19 09:48 PM
10/30/19 09:48 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Dominators do have different carb mounts.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Tunnel ram linkage [Re: Sammy] #2711454
10/30/19 11:16 PM
10/30/19 11:16 PM
Washington
Washington
Do,you have a link to that linkage? I'd like to see it.
TIA
Re: Tunnel ram linkage [Re: madscientist] #2711752
10/31/19 10:02 PM
10/31/19 10:02 PM
hemi-itis Offline
hemi-itis  Offline
Blower linkage is the same.
Re: Tunnel ram linkage [Re: wyldebill] #2711758
10/31/19 10:30 PM
10/31/19 10:30 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Not a hogan or Dominators. But you get the idea, Enderle.
