Aluminum or Copper fuel line ? #2711346
10/30/19 06:14 PM
10/30/19 06:14 PM
Washington
hemienvy Online content OP
hemienvy  Online Content OP
Washington
Trying to plan the fuel system. The pump has 3/8 NPT fittings which have a hose barb that is 1/2" OD and 3/8" ID.
So I'd like a minimum of 3/8 ID everywhere. I really don't want to use a lot of rubber line. Also, I don't know what NHRA likes,
(although that's not the biggest concern).
There is 1/2" OD aluminum line and there is 1/2" OD copper line, these should be 3/8 ID but I cannot seem to verify that.
Has anyone used either hard line without any problems ? Or what kind of problems did you have ? One problem I could see
would be corrosion with any alcohol in the fuel.
Re: Aluminum or Copper fuel line ? [Re: hemienvy] #2711353
10/30/19 06:29 PM
10/30/19 06:29 PM
E
earlymopar Offline
earlymopar  Offline
E
I used Nicopp line (nickel-copper) which is available at several locations but not so much in 3/8". I found that diameter at Advance Auto Parts.
- EM
Re: Aluminum or Copper fuel line ? [Re: hemienvy] #2711366
10/30/19 07:05 PM
10/30/19 07:05 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Both will work harden (eventually break from flexing and vibration), but aluminum sooner, copper is also easier to repair (solder) rather than make a new one.
I use Adel clips ("P" clamp with a rubber insert to protect the line against chafing and chassis vibration), and add a vibration loop midway in a long line.
Boffin Emeritus
Re: Aluminum or Copper fuel line ? [Re: polyspheric] #2711383
10/30/19 07:26 PM
10/30/19 07:26 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
FWIW, I've have 1/2" aluminum hardline on a few cars; one I did 34 years ago, another 25 years ago.
Both are still just fine, never a problem or a leak.
Support (adel clamps as noted, one car has a few tie-wraps along its subframe tie) them so they can't vibrate or flex.
I prefer to use fire sleeve over the aluminum, but haven't always (did a couple vintage T/A racecars as well, now that I think of it).
Use hose at both ends to connect to pump/engine, 6" is enough.
Check your AN fittings to be sure they're not significantly smaller ID (some are), and use a larger-ID regulator.
Re: Aluminum or Copper fuel line ? [Re: hemienvy] #2711405
10/30/19 08:17 PM
10/30/19 08:17 PM
Both aluminum and copper come in hard drawn and soft drawn tubing, both types of the hard drawn are a bear to work with twocents
I've used both on race cars with no problems other than wearing a hole in the first car I used the soft drawn copper due to me sliding and tying down the ramps under the car without making sure they weren't rubbing on anything realcrazy shruggy
Re: Aluminum or Copper fuel line ? [Re: Cab_Burge] #2711410
10/30/19 08:41 PM
10/30/19 08:41 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Aluminum or Copper fuel line ? [Re: bigdad] #2711422
10/30/19 09:31 PM
10/30/19 09:31 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
So I am the only one that runs annealed SS hardline?
Ni/Copper would be my only other candidate for fuel line..
Alum is not very robust, and any nearby fire will quickly show how little it matters how one mounted it.
Re: Aluminum or Copper fuel line ? [Re: jcc] #2711440
10/30/19 10:12 PM
10/30/19 10:12 PM
Washington
Washington
JCC, Where do you get annealed SS line ? I'd love to see what sizes are available.
Re: Aluminum or Copper fuel line ? [Re: hemienvy] #2711444
10/30/19 10:29 PM
10/30/19 10:29 PM
Washington
Washington
OK, I just read about aluminum line, so that is out.
Either copper/nickel or stainless, I would prefer stainless.
Re: Aluminum or Copper fuel line ? [Re: hemienvy] #2711473
10/31/19 01:33 AM
10/31/19 01:33 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Understand, IMO, SS is NOT the easiest to work with, even annealed, but I believe its the best, its robust, its the most fire resistant, its pricey, and it looks great.
Summit?
Re: Aluminum or Copper fuel line ? [Re: jcc] #2711477
10/31/19 02:06 AM
10/31/19 02:06 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Just removed my 30yr old aluminum line in favor of braided Teflon line. Also ditched all the rubber braided from the fuel cell to the pump.
Re: Aluminum or Copper fuel line ? [Re: J_BODY] #2711535
10/31/19 10:26 AM
10/31/19 10:26 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
I always use either braided SS line or the black cloth style braided line w/ AN fittings. Easiest and best looking IMO.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Aluminum or Copper fuel line ? [Re: an8sec70cuda] #2712059
11/02/19 11:02 AM
11/02/19 11:02 AM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
I’ve used the earls brand 1/2” aluminum tubing for my car. But next time I will use the stainless
https://www.summitracing.com/parts/ear-681696erl/
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Aluminum or Copper fuel line ? [Re: mopardude318] #2712111
11/02/19 01:58 PM
11/02/19 01:58 PM
I've also used the Summit brand of steel fuel lines with a tubing bender, it was oaky to work with up
You will need to be real careful on the short 90 degree bends going around the rear sub frame if your going to copy the original route twocents
Re: Aluminum or Copper fuel line ? [Re: Cab_Burge] #2712131
11/02/19 03:49 PM
11/02/19 03:49 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Save a few bucks with aluminum tubing, and you can use nuts and sleeves and flare it to add AN hoses for flex connections - but it's a PIA to work with, make fit, keep from kinking and I don't think it's as safe as a stainless braided or even legal fire resistant hose. Haven't used that stuff for years, Couple of rolls of it here collecting dust.
Street car? Maybe do up a steel line to replace'upgrade the original stuff, but not the aluminum.
Re: Aluminum or Copper fuel line ? [Re: hemienvy] #2712882
11/05/19 03:36 AM
11/05/19 03:36 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
As many have said, Nickel Copper tubing.
Re: Aluminum or Copper fuel line ? [Re: 451Mopar] #2712885
11/05/19 04:08 AM
11/05/19 04:08 AM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
I only use SS for fuel and brake lines up
Re: Aluminum or Copper fuel line ? [Re: Mopar Guy] #2712987
11/05/19 12:47 PM
11/05/19 12:47 PM
moparx Online content
moparx  Online Content
anyone use the eastwood [or equivalent] hydraulic flairing tool on stainless tubing ?
if so, how well did it work ?
also, did it take multiple tightening sequences to get the tubing from seeping, like other flaring methods do for a complete seal ?
TIA as always.
beer
Re: Aluminum or Copper fuel line ? [Re: moparx] #2712991
11/05/19 01:08 PM
11/05/19 01:08 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Most of the long run front to back on my car is 1/2" aluminum (summit brand). 100% E85 all the time for 7 years without an issue.
Just make sure it's secured every 12" or so to keep it from vibrating, and tuck it up high enough so it's protected.
Re: Aluminum or Copper fuel line ? [Re: moparx] #2713095
11/05/19 06:11 PM
11/05/19 06:11 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
After a few lousy attempts with the cheapo flaring tools on SS, I bought the $200+? hydraulic flare tool kit, and although still a tough task, that is the only way IMO to flare SS.
