Re: Aluminum or Copper fuel line ?
[Re: hemienvy]
#2711366
10/30/19 07:05 PM
10/30/19 07:05 PM
Posts: 4,210 New York
polyspheric
New York
Both will work harden (eventually break from flexing and vibration), but aluminum sooner, copper is also easier to repair (solder) rather than make a new one. I use Adel clips ("P" clamp with a rubber insert to protect the line against chafing and chassis vibration), and add a vibration loop midway in a long line.
Boffin Emeritus
[Re: polyspheric]
#2711383
10/30/19 07:26 PM
10/30/19 07:26 PM
Posts: 20,892 A collage of whims
topside
A collage of whims
FWIW, I've have 1/2" aluminum hardline on a few cars; one I did 34 years ago, another 25 years ago. Both are still just fine, never a problem or a leak. Support (adel clamps as noted, one car has a few tie-wraps along its subframe tie) them so they can't vibrate or flex. I prefer to use fire sleeve over the aluminum, but haven't always (did a couple vintage T/A racecars as well, now that I think of it). Use hose at both ends to connect to pump/engine, 6" is enough. Check your AN fittings to be sure they're not significantly smaller ID (some are), and use a larger-ID regulator.
[Re: bigdad]
#2711422
10/30/19 09:31 PM
10/30/19 09:31 PM
Posts: 22,718 Bitopia
jcc
Bitopia
So I am the only one that runs annealed SS hardline? Ni/Copper would be my only other candidate for fuel line.. Alum is not very robust, and any nearby fire will quickly show how little it matters how one mounted it.
[Re: hemienvy]
#2711473
10/31/19 01:33 AM
10/31/19 01:33 AM
jcc
Bitopia
Understand, IMO, SS is NOT the easiest to work with, even annealed, but I believe its the best, its robust, its the most fire resistant, its pricey, and it looks great.
Summit?
[Re: J_BODY]
#2711535
10/31/19 10:26 AM
10/31/19 10:26 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
I always use either braided SS line or the black cloth style braided line w/ AN fittings. Easiest and best looking IMO.
[Re: Cab_Burge]
#2712131
11/02/19 03:49 PM
11/02/19 03:49 PM
Posts: 11,668 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Save a few bucks with aluminum tubing, and you can use nuts and sleeves and flare it to add AN hoses for flex connections - but it's a PIA to work with, make fit, keep from kinking and I don't think it's as safe as a stainless braided or even legal fire resistant hose. Haven't used that stuff for years, Couple of rolls of it here collecting dust.
Street car? Maybe do up a steel line to replace'upgrade the original stuff, but not the aluminum.
[Re: Mopar Guy]
#2712987
11/05/19 12:47 PM
11/05/19 12:47 PM
Posts: 19,589 north of coder
moparx
anyone use the eastwood [or equivalent] hydraulic flairing tool on stainless tubing ? if so, how well did it work ? also, did it take multiple tightening sequences to get the tubing from seeping, like other flaring methods do for a complete seal ? TIA as always.
[Re: moparx]
#2713095
11/05/19 06:11 PM
11/05/19 06:11 PM
jcc
Bitopia
After a few lousy attempts with the cheapo flaring tools on SS, I bought the $200+? hydraulic flare tool kit, and although still a tough task, that is the only way IMO to flare SS.
