Valley tray for victor head and B block #2710309
10/27/19 07:46 AM
10/27/19 07:46 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
I was told there was a new billet valley tray offered for the victor head and B block, so I pm Andy for some info on it since it is his tray. He gives me a part number. I call Dave at Hughes Engines, he tells me the number is for the bat wings and there is no billet valley tray for Victor and B block. I search it out and find it on AR Engineering site. It's AR345 and it does exist. My question is, does it require the bat wings and does it fit the victor head same as it does other heads. The victor head is a little different animal the way the valley tray bolts up and Andy pics for the Indy tray is same for Victor tray. Are they the same? Anyone have actual picture of the AR345 valley tray? Thanks
Re: Valley tray for victor head and B block [Re: mopar dave] #2710361
10/27/19 12:14 PM
10/27/19 12:14 PM
AndyF Offline
AndyF  Offline
AR345 is for a low deck with Victor heads. You don't use the batwings with Victor heads. Just RTV the sides of the valley plate to the heads.
http://arengineering.com/home-page/valley-plates/
Re: Valley tray for victor head and B block [Re: AndyF] #2710397
10/27/19 03:23 PM
10/27/19 03:23 PM
Mt Morris Michigan
Mt Morris Michigan
Ok, thanks for clearing that up Andy.
Re: Valley tray for victor head and B block [Re: mopar dave] #2710504
10/27/19 11:37 PM
10/27/19 11:37 PM
AndyF Offline
AndyF  Offline
If Hughes doesn't have one in stock then have them drop ship one from me. I have several on the shelf.
Re: Valley tray for victor head and B block [Re: AndyF] #2710538
10/28/19 08:10 AM
10/28/19 08:10 AM
Mt Morris Michigan
Mt Morris Michigan
Ok, but can I order directly from your web site?
Re: Valley tray for victor head and B block [Re: mopar dave] #2710552
10/28/19 09:49 AM
10/28/19 09:49 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Andy - any sense for how much head and/or block milling impacts how your Victor valley covers fit properly?
Re: Valley tray for victor head and B block [Re: BradH] #2710595
10/28/19 12:14 PM
10/28/19 12:14 PM
AndyF Offline
AndyF  Offline
The valley plate is designed for stock deck height. It has a little room for the RTV so the deck height could be reduced some but if the deck is cut a bunch then at some point the valley plate will need to be machined to match. That is the problem with the Victor head design where it has the vertical walls on the head. That design doesn't allow for much variation in deck height.
Re: Valley tray for victor head and B block [Re: mopar dave] #2710598
10/28/19 12:15 PM
10/28/19 12:15 PM
AndyF Offline
AndyF  Offline
No. There isn't an order feature on my website. My website is for information only.
Re: Valley tray for victor head and B block [Re: AndyF] #2710635
10/28/19 02:06 PM
10/28/19 02:06 PM
Mt Morris Michigan
Mt Morris Michigan
Ok. I will contact Hughes. My deck is right at 9.980, but gonna machine heads a bunch, so will have to account for valley tray .
Re: Valley tray for victor head and B block [Re: AndyF] #2711074
10/30/19 12:12 AM
10/30/19 12:12 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Hey Andy, How about one for a low deck with mopar stage VI heads?
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Valley tray for victor head and B block [Re: HOTMOPR] #2711078
10/30/19 12:56 AM
10/30/19 12:56 AM
AndyF Offline
AndyF  Offline
You're on your own there. I'm not going to make anything special for Stage VI heads.
Re: Valley tray for victor head and B block [Re: AndyF] #2711085
10/30/19 02:00 AM
10/30/19 02:00 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Gotcha, I was hoping one of the others might work. Ill build something.. Thanks.
Re: Valley tray for victor head and B block [Re: AndyF] #2711119
10/30/19 08:12 AM
10/30/19 08:12 AM
Mt Morris Michigan
Mt Morris Michigan
Andy, if I have .050" removed from the head/gasket , how much would have to be machined from the vertical wall on the victor head?
Re: Valley tray for victor head and B block [Re: mopar dave] #2711132
10/30/19 09:22 AM
10/30/19 09:22 AM
BradH Offline
BradH  Offline
Would it be simpler (and maybe cheaper) to not cut the heads there and, instead, plan to modify the ARE plate after you can mock up everything to determine what needs to be removed?
Re: Valley tray for victor head and B block [Re: BradH] #2711192
10/30/19 11:37 AM
10/30/19 11:37 AM
Mt Morris Michigan
Mt Morris Michigan
Not sure, but shops around here change the same whether they machine the intake or the intake side of a head. I would guess it would be same deal for the valley tray. I'll have to ask.
Re: Valley tray for victor head and B block [Re: mopar dave] #2711201
10/30/19 11:50 AM
10/30/19 11:50 AM
BradH Offline
BradH  Offline
You could probably modify Andy's plate w/ a big flat file, a surface plate, and a bunch of grades of wet-or-dry sand paper. hammer
Re: Valley tray for victor head and B block [Re: AndyF] #2711202
10/30/19 11:53 AM
10/30/19 11:53 AM
BradH Offline
BradH  Offline
No more RB Victor plate?
Re: Valley tray for victor head and B block [Re: BradH] #2711218
10/30/19 12:32 PM
10/30/19 12:32 PM
Mt Morris Michigan
Mt Morris Michigan
I believe the RB/victor plate is still listed on hughes site. I just ordered the B/victor plate from hughes. Had to be dropped shipped from AR Engineering. Hughes says it was discontinued, so what Andy has left is it. They gave me a price of $165, on Andy's site its $250. I questioned the price because I wanted to be sure it was the correct plate. Tim told me I shouldn't have said anything. Doooh!
Re: Valley tray for victor head and B block [Re: mopar dave] #2711268
10/30/19 02:34 PM
10/30/19 02:34 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I might have missed it, but is something wrong with the regular bolt on valley pan?
Re: Valley tray for victor head and B block [Re: Jeremiah] #2711284
10/30/19 03:06 PM
10/30/19 03:06 PM
Mt Morris Michigan
Mt Morris Michigan
The tin pan works fine as is, but the billet tray has a removable cover making things easier with cam changes and is a quality piece.
