Re: Valley tray for victor head and B block
[Re: BradH]
#2710595
10/28/19 12:14 PM
10/28/19 12:14 PM
Posts: 31,056 Oregon
AndyF
Andy - any sense for how much head and/or block milling impacts how your Victor valley covers fit properly? The valley plate is designed for stock deck height. It has a little room for the RTV so the deck height could be reduced some but if the deck is cut a bunch then at some point the valley plate will need to be machined to match. That is the problem with the Victor head design where it has the vertical walls on the head. That design doesn't allow for much variation in deck height.
[Re: mopar dave]
#2710598
10/28/19 12:15 PM
10/28/19 12:15 PM
AndyF
Ok, but can I order directly from your web site? No. There isn't an order feature on my website. My website is for information only.
[Re: AndyF]
#2711074
10/30/19 12:12 AM
10/30/19 12:12 AM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
Hey Andy, How about one for a low deck with mopar stage VI heads?
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: AndyF]
#2711085
10/30/19 02:00 AM
10/30/19 02:00 AM
HOTMOPR
Oakville, Wa
You're on your own there. I'm not going to make anything special for Stage VI heads. Gotcha, I was hoping one of the others might work. Ill build something.. Thanks.
[Re: mopar dave]
#2711132
10/30/19 09:22 AM
10/30/19 09:22 AM
BradH
Andy, if I have .050" removed from the head/gasket , how much would have to be machined from the vertical wall on the victor head? Would it be simpler (and maybe cheaper) to not cut the heads there and, instead, plan to modify the ARE plate after you can mock up everything to determine what needs to be removed?
[Re: mopar dave]
#2711268
10/30/19 02:34 PM
10/30/19 02:34 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I might have missed it, but is something wrong with the regular bolt on valley pan?
