Re: FAST - Ed Cook goes 10.26 @ 131.70
[Re: pittsburghracer]
#2711327
10/30/19 05:24 PM
10/30/19 05:24 PM
Posts: 2,094 central texas
krautrock
central texas
Amazing car! Do they typically run factory carbs (i.e. AVS, AFB, Holley 4160 etc) or can you cheat and use an Edelbrock or holley hp place of the OEM carb? Everything but the block is supposed to be factory OEM parts with correct part numbers. You can do what ever possible to make your parts better as long as they keep there stock appearance. I do not treat the tires. I shave them down to the wear bars and start burning em up from there. A good set of tires are priceless! So you are saying it’s an aftermarket block with stock pistons, cranks, rods, cams, intake manifolds, carbs, etc etc, but they can use a tire and compound that is modified. If so that’s super fast for that combo. Even for Fall type weather at an east coast track. Congratulations i think they can use stroker cranks, different rods and pistons, but the heads have to appears stock, the intake has to be stock, same with carbs and exh manifolds... cam is whatever they want to run, but not sure if it has to sound stock???
[Re: krautrock]
#2711329
10/30/19 05:30 PM
10/30/19 05:30 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
It’s really pretty easy....... “Correct” castings for heads, intake, exhaust, carbs.
You can do anything to them that doesn’t appear incorrect when the motor is fully assembled.
If you’re not a front runner type car, then using the exactly correct heads, intake, carb, etc isn’t quite as important.
For example, if you have a 70 GTX 440 4bbl combo running 12.70’s, no one is going to be upset that you have 452 heads on the motor instead of 906’s.
[Re: fast68plymouth]
#2711428
10/30/19 09:46 PM
10/30/19 09:46 PM
Posts: 643 southern conn
1969gtx
southern conn
grate job Ed can't wait to see how fast it goes with a little more sorting I can see it going 9.80s or faster
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
#2711483
10/31/19 03:46 AM
10/31/19 03:46 AM
Posts: 28 Germany
stickman60
Germany
So you are saying it’s an aftermarket block with stock pistons, cranks, rods, cams, intake manifolds, carbs, Those are usually big displacement engines (Hemis @498cu. ?, others up to 600cu) with 'stock' internals, custom cams with long duration, extrude honed exhaust manifolds and probably intakes as well. Absolutely amazing.
[Re: DonnyBrass]
#2711604
10/31/19 01:02 PM
10/31/19 01:02 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
I love 63 Plymouths, 2 door hard top and sedans I've own and race several of them, the Aluise family owns my 415 HP Belevdere 2 door sedan old NHRA stocker and they have set the NHRA record in A/SA several times with it years ago. My old M.W. Belevedere 2 door hardtop is in Finland now, not sure if it is being raced still or not anymore I have a 1963 2 door Fury now that I'm planning on making it into a nice street car
[Re: Beeware]
#2712580
11/04/19 01:06 AM
11/04/19 01:06 AM
Posts: 7,480 Minnesota
Hemi_Joel
Minnesota
Atta boy, Ed! That thing is really hauling the mail.
Ron, all cars have to use the stock rim diameter:
14.00 TIRES AND WHEELS AND BRAKES 14.01 Wheels must be correct*, including correct* diameter, width and material. Note: Width may be upgraded to a maximum of 6”, if the correct* wheel is narrower than that. Reproduction wheels OK. 14.02 All 4 wheels and tires must be same size. Exception: Mopar TA Challenger came from factory with G-60’s on rear and F-60’s on front. 14.03 Original equipment reproduction bias-ply tires only. No soft compound tires of any kind are allowed. Retread tires are not allowed. Any car is allowed to upgrade to a maximum size tire of G-70 of the correct* wheel diameter. All cars that were originally available with a 60 series tire can upgrade to a maximum size of G-60 tire of the correct* wheel diameter.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: XXHEMI]
#2712720
11/04/19 03:47 PM
11/04/19 03:47 PM
Posts: 2,814 Connecticut
FurryStump
Connecticut
Amazing car! Do they typically run factory carbs (i.e. AVS, AFB, Holley 4160 etc) or can you cheat and use an Edelbrock or holley hp place of the OEM carb? Everything but the block is supposed to be factory OEM parts with correct part numbers. You can do what ever possible to make your parts better as long as they keep there stock appearance. I do not treat the tires. I shave them down to the wear bars and start burning em up from there. A good set of tires are priceless! I didn’t know “shaving them down” stands for doing burnouts, late at night, under the cover of darkness way out in the back of the pits? Hehehehehe
[Re: Hemi_Joel]
#2714424
11/10/19 01:53 AM
11/10/19 01:53 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
14.00 TIRES AND WHEELS AND BRAKES 14.01 Wheels must be correct*, including correct* diameter, width and material. Note: Width may be upgraded to a maximum of 6”, if the correct* wheel is narrower than that. Reproduction wheels OK. 14.02 All 4 wheels and tires must be same size. Exception: Mopar TA Challenger came from factory with G-60’s on rear and F-60’s on front. 14.03 Original equipment reproduction bias-ply tires only. No soft compound tires of any kind are allowed. Retread tires are not allowed. Any car is allowed to upgrade to a maximum size tire of G-70 of the correct* wheel diameter. All cars that were originally available with a 60 series tire can upgrade to a maximum size of G-60 tire of the correct* wheel diameter. Thanks Joel. Congrats again Ed as I love that 63 of yours. Ron
