Electrical issue #2710437
10/27/19 07:06 PM
10/27/19 07:06 PM
Star Idaho
67vertman Offline OP
Star Idaho
1970 Cuda,
Strange thing happened last night. I took my car to a show, on the way home I was told my rear lights where out (running/brake/turn signals), I pulled over to check things out. Nothing seemed out of the ordinary, (lose wire/ground) looked at the fuses, everything okay. I jump back in and try the light switch, then moved the dimmer switch, dash lights went out, now I am scathing my head. Got out checked the tail lights, everything working back there but no dash lights. I decide to drive it home. Today I go over everything, power to the dash lights, dimmer switch but still no dash lights. Did the dimmer switch cause the tail lights to fail? I think I need to replace the switch?
Is there something I am missing.
My Monster are real!
Living within your means makes life pretty easy.
Re: Electrical issue [Re: 67vertman] #2710501
10/27/19 11:30 PM
10/27/19 11:30 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Is the dimmer switch you are talking about the switch and changes the brightness of the dash lights? If it is, yes, that dimmer switch and take out the dash lights. The switch has a rheostat that an arm runs against, its not unusual for that rheostat to have a bad spot that will disconnect the power to the dash lights. Sometimes you can turn the rheostat a few times through the range and it will work fine afterwards, and sometimes its just plain dead. There should be a full on brightness place at the upper end of the dial that nearly always works, if you can live with the dash lights being full bright. If the switch is dead, you need to replace it. Gene
Re: Electrical issue [Re: poorboy] #2710510
10/27/19 11:59 PM
10/27/19 11:59 PM
Star Idaho
Star Idaho
Yes that the switch I am talking about. I took it out again tonight. I noticed that if I put on the bright lights (high beams) the dash lights come back on.
I will start looking for a new dash light switch. Anybody know who sales them or rebuilds them?
Re: Electrical issue [Re: 67vertman] #2710521
10/28/19 03:55 AM
10/28/19 03:55 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Jim at www.jsrestorations.com
Original ebody dimmer switches blow, I never install one without Jim restoring it first, saves on many potential problems down the road.
Re: Electrical issue [Re: poorboy] #2710522
10/28/19 04:04 AM
10/28/19 04:04 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Running/dash lights runs in one circuit and brakes/turning runs in another circuit. If you have both system lights failed and you are sure ground to tail lights is ok, you are getting two issues at the same time with that.
Check fronts if work to beging the discarding process.
Dash lighting has nothing to do with tail lights But JUST sharing the input source for running lights ( even less with turnings ). That could become in a 3rd issue diff from the other two
Re: Electrical issue [Re: NachoRT74] #2710525
10/28/19 05:14 AM
10/28/19 05:14 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Id have to look it up but as I remember if you lose the tail lamp feed you lost dash lights. The dash lamp fuse feed was supplied by the tail lamp fuse. I'd take a look at the fuse block. Is it corroded? Many times the fuse holders are rusty. Occasionally the are bad enough to get hot and melt the block itself.
Doug
Re: Electrical issue [Re: dvw] #2710534
10/28/19 07:46 AM
10/28/19 07:46 AM
NW New Jersey
RSI700VIPER Offline
RSI700VIPER  Offline
NW New Jersey
Confirm your switch pod is properly grounded. There is a long metal tab which is part of the switch frame that makes contact to dash frame when the pod is screwed into place. This ground tab provides all of the grounding for the switches and a loose screw or some oxidation on the frame will prevent proper grounding.. Electrical problems can usually be traced to a bad ground.
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: Electrical issue [Re: RSI700VIPER] #2710582
10/28/19 11:21 AM
10/28/19 11:21 AM
Star Idaho
Star Idaho
Thanks Guys. It looks like I have more detective work to do.
I hope it is not multiple issue, but its looking like that will be the case. whiney
Re: Electrical issue [Re: dvw] #2710824
10/29/19 03:02 AM
10/29/19 03:02 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Yes is true BUT, you can loose dash lights and also still have tail lamps, because they got an extra fuse on the output
I'm meaning to check fronts ( and sides ) because tail lamps on parking function are feeded the same than sides and fronts, so if tail lights were lost, the rest are too.
Same about turning signals ( which can be checked on dash too, because they are spliced from front circuit ). Of course this excludes brakes.
Re: Electrical issue [Re: NachoRT74] #2710825
10/29/19 03:26 AM
10/29/19 03:26 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
If you actually lost the tail lites , brake lites and turn signals all at the same time I would definetly check the grounds in the rear real good because they are all on different feeds. Turn signals are a 12 volt key on feed through the flasher to the turnsignal switch and brake lites are the same bulbs as turn signals but they are a 12 volt hot all the time feed to the turn signal switch. And dash lites and tail lites are also hot all the time when the headlite switch is on as they feed through the headlite switch and then through a fuse. As said it could be more then one problem but if the front park lites did still work and all the exterior lighting trouble was in the rear lites make sure the ground for the rear lites is good. Cant tell you how many times I see dash lites go out or flicker in older muscle cars from the headlite switch rheostat trouble also. Good luck with it. Ron
Re: Electrical issue [Re: 67vertman] #2710942
10/29/19 02:32 PM
10/29/19 02:32 PM
You may want to check the plug behind the drivers side lower kick panel to make sure it is tight and no corrosion, it feeds all the lights in the trunk scope
Re: Electrical issue [Re: Cab_Burge] #2710958
10/29/19 03:33 PM
10/29/19 03:33 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Usually when turning on one item and it causes another thing to react is most likely a ground problem...
Re: Electrical issue [Re: AARCONV] #2711190
10/30/19 11:36 AM
10/30/19 11:36 AM
Star Idaho
Star Idaho
Thanks for the ides and possible cause everyone. up
It may be a while before I get to the root of the issue(s). whiney as I am busy the rest of the week.
I will update once I get a chance to work on it. wrench
