Electrical issue
#2710437
10/27/19 07:06 PM
10/27/19 07:06 PM
Posts: 4,740 Star Idaho
67vertman
Star Idaho
1970 Cuda,
Strange thing happened last night. I took my car to a show, on the way home I was told my rear lights where out (running/brake/turn signals), I pulled over to check things out. Nothing seemed out of the ordinary, (lose wire/ground) looked at the fuses, everything okay. I jump back in and try the light switch, then moved the dimmer switch, dash lights went out, now I am scathing my head. Got out checked the tail lights, everything working back there but no dash lights. I decide to drive it home. Today I go over everything, power to the dash lights, dimmer switch but still no dash lights. Did the dimmer switch cause the tail lights to fail? I think I need to replace the switch?
Is there something I am missing.
My Monster are real!
Living within your means makes life pretty easy.
Re: Electrical issue
[Re: poorboy]
#2710510
10/27/19 11:59 PM
10/27/19 11:59 PM
67vertman
Star Idaho
Yes that the switch I am talking about. I took it out again tonight. I noticed that if I put on the bright lights (high beams) the dash lights come back on.
I will start looking for a new dash light switch. Anybody know who sales them or rebuilds them?
[Re: poorboy]
#2710522
10/28/19 04:04 AM
10/28/19 04:04 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Running/dash lights runs in one circuit and brakes/turning runs in another circuit. If you have both system lights failed and you are sure ground to tail lights is ok, you are getting two issues at the same time with that.
Check fronts if work to beging the discarding process.
Dash lighting has nothing to do with tail lights But JUST sharing the input source for running lights ( even less with turnings ). That could become in a 3rd issue diff from the other two
[Re: dvw]
#2710534
10/28/19 07:46 AM
10/28/19 07:46 AM
Posts: 1,149 NW New Jersey
RSI700VIPER
NW New Jersey
Confirm your switch pod is properly grounded. There is a long metal tab which is part of the switch frame that makes contact to dash frame when the pod is screwed into place. This ground tab provides all of the grounding for the switches and a loose screw or some oxidation on the frame will prevent proper grounding.. Electrical problems can usually be traced to a bad ground.
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5 1969 Daytona Charger 440 4-Speed, Dana, EV2 1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7 1970 340 Six Pack Callenger T/A 4-speed T8 Tan 1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth 1969 Talladega Torino, 428CJ 1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
[Re: RSI700VIPER]
#2710582
10/28/19 11:21 AM
10/28/19 11:21 AM
67vertman
Star Idaho
Thanks Guys. It looks like I have more detective work to do. I hope it is not multiple issue, but its looking like that will be the case.
[Re: dvw]
#2710824
10/29/19 03:02 AM
10/29/19 03:02 AM
NachoRT74
Valencia, España
Id have to look it up but as I remember if you lose the tail lamp feed you lost dash lights. The dash lamp fuse feed was supplied by the tail lamp fuse. Yes is true BUT, you can loose dash lights and also still have tail lamps, because they got an extra fuse on the output I'm meaning to check fronts ( and sides ) because tail lamps on parking function are feeded the same than sides and fronts, so if tail lights were lost, the rest are too. Same about turning signals ( which can be checked on dash too, because they are spliced from front circuit ). Of course this excludes brakes.
[Re: AARCONV]
#2711190
10/30/19 11:36 AM
10/30/19 11:36 AM
67vertman
Star Idaho
Thanks for the ides and possible cause everyone. It may be a while before I get to the root of the issue(s). as I am busy the rest of the week. I will update once I get a chance to work on it.
